Like Tree13Likes
Old 06-16-2014, 11:58 PM
Gav's Avatar
Gav Gav is offline
Default Post Mortem
Hi all,
After a lengthy wait I finally pulled the engine from my car to assess the damage from Shelbyfest.
Well as I thought it aint real pretty in there, the #1&2 conrod big ends are blue as is the crank on that journal
Not happy Jan...
Be warned pro Ford comments will be met with profanity.
Powered by Cu
Old 06-17-2014, 12:28 AM
sambo's Avatar
Sorry to hear Gav. New crank and rods or could it be worse than that?
Old 06-17-2014, 12:43 AM
Gav's Avatar
Gav Gav is offline
I was hoping to just be bearings and maybe a couple of rods.
I won't know until everything gets measured to check for damage.
Throwing another taxi motor in for the short term is looking good!
Powered by Cu
Old 06-17-2014, 12:45 AM
ouch that's gotta hurt my engine builder had a v8 super car crank in his shop the other week that was a pretty shade of blue not sure if he repaired it or not it was sitting next to the crank grinder last I saw it may be in the bin now lol
Old 06-17-2014, 02:10 AM
Cobra Make, Engine: Python
Whilst sympathetic to your pain Gav..........the question has to be asked, how often does one stick their chin out only to have it whacked when the product fails to meet expectation ? The colour of your crank is trying to tell you something........... come across and all will be good. Aluminator XS is your friend, so please............help yourself and be happy !
Good luck with the path you take regardless mate.
Chris & Melissa
Gav and Rog246 like this.
Old 06-17-2014, 02:21 AM
Modena's Avatar
Any coroner pics?
Ben in AU
Old 06-17-2014, 03:32 AM
damage's Avatar
Cobra Make, Engine: Kirkham 427SC 482 Cammer
Repair kit
Ford Racing Coyote 5 0 Crate Engine M 6007 M50 Mustang Street Rod Cobra Shelby | eBay
Old 06-17-2014, 04:02 AM
sambo's Avatar
Hopefully just bearings Gav. Any idea what caused it - dodgy oil pump, starvation?
Old 06-17-2014, 05:18 AM
PSYCHO's Avatar
Cobra Make, Engine: FFR, GT FPV 5.4L 290kw Boss
Sorry to hear this GAV the last time I heard of a LS motor suffering that type of damage was in my sons Maloo after he gave it a hard time, when we pulled it down I found some thread tape in the crank oil journal which none of us had any idea where it came from maybe a oil temp switch or something luckily a regrind and new bearings fixed it but a whole lot of work at the end of the day. Hope it all goes well for you and that its not to terminal.
Old 06-17-2014, 06:02 AM
Gav's Avatar
Gav Gav is offline
Definitely oil starvation.
Improving the oil system or slowing down is what I am going to need to do next
Powered by Cu
Old 06-17-2014, 06:32 AM
Wazza's Avatar
I know where there is a big pile of these....
Holden VF HVS GTS LSA 6 2L 556 HP Supercharged Crate Engine 82457541 | eBay
I saw a pile of 10 of these last week.....just waiting for you Gav.
Warren.
Old 06-17-2014, 06:46 AM
Gav's Avatar
Gav Gav is offline
I think I'll need a new home too if I buy one
Wazza likes this.
Powered by Cu
Old 06-17-2014, 09:22 AM
I don't have a ton of LS experience, but it seems like a lot of them have oiling issues to the rod bearings. Last one I built was a 402 cubic inch road race engine for a guy. The core he brought me was an LS2 core and it had 2 spun rod bearings.
Crank probably needs to be reground, rods need to be replaced. Throw some new bearings in it, a good oil pump and pickup, and let her roll.
Old 06-17-2014, 09:57 AM
Bill D's Avatar
Chuckle
Old 06-17-2014, 09:58 AM
eschaider's Avatar
If you blued the journal(s) and depending on how deep the OEM nitriding penetrated, you may also need to renitride the crank after grinding. For the price of a new crank, especially if the old journals have been blued, you might just be better off with new.
Wet sump oiling systems range from poor to better than average. To get to the better than average threshold you end up spending money. If you do nothing to your oiling system this failure will reoccur. With the availability of OEM dry sump technology on the LS7 engines why not use the best priced, best performing pieces from the factory and the aftermarket and build your own dry sump system for the engine — it will serve you much better.
Ed
Gav likes this.
Old 06-17-2014, 06:24 PM
Gav's Avatar
Gav Gav is offline
I should probably add that I had improved the oiling system prior to this happening.
It has a high volume oil pump, a windowed or road race sump and is over filled for track duty.
Winton is a hard track on engines as many of us that have trashed something going around the sweeper.
If I am going to continue to race I will need to do something like dry sumping so it won't happen again no matter how hard it is thrown through corners.
Powered by Cu
Old 06-17-2014, 06:28 PM
I was pretty sure the LS pump was in the front of the engine, and assumed the front of the engine would get oil first. Wrong! A quick internet search showed that the pump is indeed in the front of the engine, but the front mains are the last thing to get oiled. They route the oil to the back of the engine, through the filter, and then up to the cam bearings. The oil then works its way to the mains, one at a time, until it gets to the front of the engine.
What a crappy oil design! You may want to do some searches for oiling improvements for that engine. It is a very popular engine. I have to believe that someone racing this engine has came up with some oil routing improvements.
Old 06-17-2014, 06:38 PM
Gav's Avatar
Gav Gav is offline
Something has to be oiled last you know
The C5Rs at LeMans are dry sump with no major other changes.
Works for them.
Powered by Cu
Old 06-17-2014, 06:53 PM
Default Piles
Wazza,
Gav already has piles...........
Good luck with the unopened LS Gav
Stiffy
Old 06-17-2014, 07:44 PM
Gav if you need a crank, this mob are pretty good. I've used them.
newsletter@precisionintl.com
This link should get you there, reasonably priced
Rog 246
Harrison #100
