Old 08-08-2014, 01:13 PM
Default Tremec tko oil
What oil .Other than dexron3 and gm sync oil,can be used in TKO
Peter
Old 08-08-2014, 01:36 PM
Dwight's Avatar
Smile
Pennzoil #7161193501
Dwight
Old 08-08-2014, 01:47 PM
The best:
Old 08-08-2014, 02:42 PM
Thumbs up
Peter
Pete, the guys on the ford Forum that I regularly visit all swear by Mainlube,
Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w80 (gearbox)
It Ain't cheap ! However the results appear to speak for themselves.
Rog
Rog 246
Harrison #100
Old 08-08-2014, 03:25 PM
DAVID GAGNARD's Avatar
I've used the recommend GM oil as well as RedLine MTL (manual transmission lubricant),both o-k to use in Tremecs,could not tell any difference in the two,bought whichever one was the easiest to find at the time I needed it........
DAVID GAGNARD
Old 08-08-2014, 03:58 PM
Modena's Avatar
I am planning on using this;
Penrite Oil - A Better Class Of Oil
Ben in AU
Old 08-08-2014, 08:28 PM
bobcowan's Avatar
Around here, Royal Purple, GM, and Pennzoil are readily available. I'v tried them all. The Pennzoil made for hard shifts and missed shifts. I drained that out after one race week end.
The other two seemed to be about the same, couldn't really tell the difference. I use GM, because it's a little bit cheaper.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 08-09-2014, 12:07 AM
Question
I was thinking of using penrite 75/90 pro gear after reading something on this forum
