Like Tree2Likes
  • 2 Post By Russell9318
Old 10-10-2014, 02:12 PM
Russell9318's Avatar
Cobra Make, Engine: Pace 427S, Coyote Aluminator
Default Hydraulic Throw Out Bearing
I am about to purchase an hydraulic throw out bearing set up and want to know if anyone can recommend a good reliable system. Reviews run hot and cold on these so some words of wisdom from those who know would be appreciated
Russell
Old 10-10-2014, 03:01 PM
Mrs flatchat's Avatar
Wink
What gearbox ?
Old 10-10-2014, 03:06 PM
Originally Posted by Mrs flatchat View Post
What gearbox ?
I am using a TKO-600 behind a Coyote with Quick Time Bell Housing
Old 10-10-2014, 03:36 PM
Wink
May I suggest talk to Mal Wood (the Tremec man) as he does these systems on a regular basis
He's waiting for your call now :-)
Old 10-17-2014, 07:38 AM
Bryan Wilson's Avatar
Default Hydrolic throwout bearing
I run a Mcleoud bearing in my Cobra and the only drawback is the pedal pressure needed to push the pedal to the floor, although you do get used to it when leg strength increases over time. The bearing in combination with the Hays race clutch plate works like an on off switch.
Cheers Bryan
VK3KDN
Old 10-17-2014, 08:09 AM
Cobra Make, Engine: SPF GT40
If you're thinking internal hydraulic bearing (slave cylinder inside the bellhousing) don't get a McLeod. Had McLeod fail 3 times on my GT40. Pain in the butt to remove each time. Tilton makes much better ones.
Old 10-17-2014, 12:48 PM
Thanks for the comments folks.
Mal Wood has provided information on the system he makes and from what I gather, it should do the job nicely and not too expensive and good to get an Australian product so I think I will go with Mals kit.
Russell
Mrs flatchat and Towmaster like this.
Old 10-18-2014, 04:41 AM
Cool
At SwiftDB4 --what actually failed in your hydraulic release bearing ?
seals, orings, bearing, hoses, housing or just plain wrong set up ??
In order to better improve the product / instructions :-)
