Old 11-15-2014, 05:06 AM
joyridin''s Avatar
Default Question for guys running LS engine
I figured I would try posting here since a vast number of you run LS engines.
I currently have a SBC with a Lakewood blow proof housing mated to a T56. Between the T56 and bellhousing, there is an adapter that allows you to use the original lever style throwout bearing.
Is there a bellhousing or a way that I can install an LS engine that will still allow me to use the current lever style throwout bearing arm? I prefer not to use the new style throwout bearing that is mounted to the trans.
Old 11-15-2014, 06:27 AM
bobcowan's Avatar
I wanted the same thing you do. But I couldn't find anything. It may be out there, but I couldn't find it.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 11-15-2014, 11:05 AM
Gaz64's Avatar
This thread may be some help:
Who has done T56 6 speed swap? [Archive] - TriFive.com, 1955 Chevy 1956 chevy 1957 Chevy Forum , Talk about your 55 chevy 56 chevy 57 chevy - Belair , 210, 150 sedans , Nomads and Trucks, Research, Free Tech Advice
This is where I googled the above from:
t56 clutch fork conversion - Google Search
Old 11-15-2014, 05:45 PM
joyridin''s Avatar
Well, it looks like Quicktime Might make one. I have to do some checking.
Thanks for the info!
