Like Tree8Likes
Old 11-27-2014, 10:39 PM
spf645's Avatar
Cobra Make, Engine: Superformance, 351w
And I also have the AVO shocks as well. No leaks last time checked. Car is only street driven though. Wish they had the height adjustment. I hated the was way SPF cars appear to sit high in the rear, so had to move the rear upper shock mounting arm up one hole to get the look I was after. Maybe it doesn't handle as well for those who track their car, but sure looks much better. Least I think so.
Old 11-28-2014, 01:04 AM
AVO AVO is offline
I'm surprised that there is no height adjustment. Can you send me a photo?
Old 11-28-2014, 02:23 AM
sambo's Avatar
Can someone explain how dampers just snap like that?
Old 11-28-2014, 02:38 AM
AVO AVO is offline
It is sometimes due to an incorrect design. If a too long shock is fitted, it can bottom too much. Additionally, if there is not enough clearance at the mounts, a bending moment can eventuate, and cause some stress on the shaft. Hitting a curb or big hole can also do some damage.
Old 11-28-2014, 09:39 AM
spf645's Avatar
AVO,
Sorry, I',ve never been able to get pics of anything to load to site. Some issue with me not knowing just how I'm sure. But no, no height adjustment on mine, (AVO). Just the one ring for spring pressure.
Brett
Old 11-28-2014, 12:14 PM
AVO AVO is offline
Brett,
If you cant adjust the ride height with the adjusters, this suggests either your springs are too long, or the shocks too short.
Old 11-29-2014, 08:52 AM
spf645's Avatar
Cool
AVO
I was thinking of other types of shocks I'd seen that I believe had 2 rings. 1 for spring rate adjustment, and other 1 for maybe adjusting an inner sleeve I thought for height adjustment. I'm probably confused at what I thought each ring purpose was for.
I did get to spend a short time with car on corner scales after I'd adjusted ride height as you say to. But it doesn't take much adjusting when trying to get corner weight, and cross weight close to where it should be, before ride height is not as I'd like. Need my own scales, where time wouldn't be an issue. A 4 wheel alignment was the best thing I'd had done though. My, what a driving improvement.
Sorry all, didn't mean to get off thread topic.
Old 11-30-2014, 05:40 PM
boxhead's Avatar
I thought mine may have been due to binding at full compression, but there was plenty of clearance around the top hat of spring and the shock does not bottom out before the lower control arm contacts the chassis.
I thought it must have been a "one off", until I heard it has happened to others.
Cruising in 5th
Old 12-04-2014, 03:50 PM
Cobra Make, Engine: Harrison #102 Ford 5l Fuel Injected AU 2
Default Coil Over Shocker Problems
Thank you all for replies re my thread. I was surprised that the Leaking problem was not specific to any one kit builder seemed across the board. My shocks were serviced by a fellow recommended by Harrison in Brisbane with no better result than the brand new ones out of the box one leaked.I have put my hand up for a set of Strange single adjustable Shocks only and will have the spring retainers machined to suit the King coil ID of 2.375" int Dia, (thanks to Muzza).After several phone calls to Engine Master Albury checking the Strange dimensions etc, and agreeing on a Price sub $1000- then ordering to be told sorry out of stock for those units. On back order hopefully 2 weeks ???
Hoping to be back on the Sunny Coast roads before Xmas.
To you all have save Xmas and enjoy your Cobras.
BJ's Snake and Towmaster like this.
Old 12-04-2014, 03:59 PM
Towmaster's Avatar
Trevor when I get my Cobra back on the road I will join you and Steve B for a cruise .....
Old 12-04-2014, 04:00 PM
Aussie Mike's Avatar
One thing to think on. Strange make shocks for Drag racing. Will the valving be suitable for a Cobra road car?
Mike Murphy
Melbourne Australia
Old 12-05-2014, 02:26 AM
AVO AVO is offline
Trevor,
I have all the parts and tools that could fix your leaking problem. Cost often works out to around 1/3 rd of new replacement cost. Over to you.
  #33 (permalink)
Old 12-08-2014, 09:07 PM
Default Strange
I"am going to find out soon enough hopefully when they arrive?????????
