Like Tree100Likes
Old 09-18-2016, 03:25 AM
thanks CK..
No seals as standard, I do have a D section clip on seal for the window frame, then two stages of rubber seal around the door.. one near the door lip and a second 2 part compression seal near where it meets the body. Should be water tight.. Remade one hinge plate this afternoon to get a little extra travel..
Remade the crash bar and uprights for the door frame this morning.. managed to put a nice bend it it while I was welding out of sequence... ! Does anyone in Sydney have access to a press...?
EDIT.. used the car wheel and a couple of blocks of wood with a variable pivot point to straighten the door frame rail.. not completely, but sufficient to make it workable..
FFR Coupe 65
LS3 motor, TR6060 box with Falcon ABS, 17" Halibrand wheels, 3.55:1 Ford Racing IRS and Willwood brake upgrade
