Like Tree2Likes
  • 2 Post By muzzza
Old 03-05-2015, 12:36 AM
leroy17's Avatar
Default Laser cutter - steel - seeking some brackets to be made
Hey guys,
Just checking to see if anyone has or has access to a laser cutter for steel. I am seeking some brackets to be cut from 6mm steel.
I know that there are places that do this, which I will use as a last resort, however was being a tight ar$e and trying to save a little as I am only after two brackets styles, 4 pieces of each.
This is for from shock mounting (upper and lower).
Cheers.
Old 03-05-2015, 12:50 AM
weld on shock mounts like this any good to you ? I use these a lot on the race car
Pack OF 4 Weld ON Shock Mount Kits Includes NUT Bolt AND Spacer Speedway Drag | eBay
Old 03-05-2015, 02:21 AM
DaveW's Avatar
6mm is a pretty stock item for fabricators, and lazer cutters.
You would be surprised how cheap it will be if you got him to cut when they do a run, rather than have them set up specially.
Also, most of the expenses is usually the initial drawing, if you do this yourself, will save as well.
Dave
Old 03-05-2015, 04:41 AM
leroy17's Avatar
Thanks guys, got me thinking and there are some alternatives.
This weekends project.
Old 03-05-2015, 12:22 PM
Leroy
McDonald Bros Racing have a variety of brackets precut .
Check there website.
Iva Bigan
Old 03-05-2015, 02:21 PM
Leroy,
A couple of 18TPI hacksaw blades, basic drill press and files..........Only 6mm ..........you'll have them done in two shakes !! ( add a little sweat for Queensland ) Let me know if you want drawings ( dxf or dwg ) Muz
Modena and Cobra01 like this.
Old 03-05-2015, 03:14 PM
leroy17's Avatar
Originally Posted by muzzza View Post
Leroy,
Thanks Muz, whilst I have taken this route for nearly everything I have made so far, I was liking the options of the pre cut, and then weld on.
McDonald Bros has exactly what I am looking for, so thanks to iva bigan however I may get the drawings from you anyway as I have a few ideas.
Thanks mate.
