Like Tree97Likes
Old 07-29-2015, 05:01 PM
Default Scoops
Matt, the central bulge is open to the rear and sucks the engine heat out. The 2 x front facing scoops either side of the centre bulge push cool air into the engine bay. The 2 smaller forward facing vents on the scupper panel close to the windscreen direct cool air to the foot wells.
Old 09-03-2015, 04:43 AM
750hp's Avatar
I received an email today that contained this super cool photo...
Aussie Mike, boxhead, mate and 3 others like this.
Craig
Old 09-03-2015, 04:07 PM
Towmaster's Avatar
AAhhhhhhhh the Karussell.
Bloody rough bit of concrete!
Old 09-03-2015, 05:17 PM
leroy17's Avatar
Neutral
I got taken for a lap in the continental tyres GT2 driven by Horst Von Saurma (see link, https://en.wikipedia.org/wiki/Horst_von_Saurma) and despite it being the most increadable car experience in my life, when we dropped into the Karussell after the rest of the track, I got double vision and cracked a rib, maybe not cracked, but it's rough).
Just an awesome photo though.
Old 09-03-2015, 07:13 PM
PeterAllen's Avatar
Looks to be going hard - probably trying to chase some GTOs!
Old 09-04-2015, 12:54 AM
David Hodgson's Avatar
To lap them for the second time
Gav likes this.
SLIPRY
Old 09-04-2015, 03:20 AM
PeterAllen's Avatar
The veracity of that ludicrous claim will be tested at Goodwood next weekend, where I am prepared to bet my house that Ferraris will finish first, second and third in the Lavant Cup race.
Old 09-04-2015, 04:23 AM
jcraigau's Avatar
That is certainly a great shot!
The drop into Karussell is quite an eye opener but nothing compared to being shot out the other side!
Old 09-04-2015, 04:28 AM
I'll take some of that action Pete!
boxhead likes this.
Old 09-04-2015, 05:52 PM
Pete, I guess the Lavant Cup is for Ferraris only then
Gav likes this.
SLIPRY
Old 09-05-2015, 01:10 AM
Modena's Avatar
still a big call that they will finish
Gav likes this.
Ben in AU
Old 09-08-2015, 06:22 PM
Default New wheels and tyres
Hi, well I'm finally getting to the car to measure up some new rims and tyres for it. The current rims and tyres are
Rear 295/30 18 on 18 x 10.5 +25mm OS/170mm backspace +4mm spacer
Front 265/35 18 on 18 x 10 +31mm OS/170mm backspace
The current set up sticks out 15mm from the rear guards and fouls the coilover without the spacer and the front scrub on full lock on the A arms.
So unlike cobras I want a taller or equal tyre profile in the rear. I need to stay with 18's due to my large brakes.
So far, I reckon I have the rears correct. They'll be 275/40 18 NTO1's 18 x 9.5with +28mm OS/161.35 backspace. They sit in under the guards at full compression and miss the coil overs internally at full droop.
The fronts are more of a question. (the fronts in the pic aren't exactly what I'm looking to do. They are 235/40 18 on 18 x 8.5) so a 245/40 will be taller and fuller looking but same essentially frontspace position.
I either go 245/40 on 18 x 8 or 275/35 on 18 x 9.5. Any thoughts or comments?
(The links below may help others work out their desired sizes if they're looking to fit new wheels.)
Current:
Proposed
NT01 D.O.T.-Compliant Competition Road Course Tire
Tyre Size Calculator
Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Wheel Offset/Backspace Calculator - Calculate/Compare Wheel Offset and Backspace
I know Serpent (Theo) has mentioned he runs 18 x 9.5 with a 150mm backspace (+16.65mm offset) all round but there is no way that OS will clear my rear coil overs in teh rear and it'd protrude my front guards another 8mm more s just goes to show all cars are different.
So feedback on using an 8inch wide front or 9.5 would be appreciated. I've got planet of spare race rims for the car so essentially is road and drive to sprints fun as well as making the car look a little more correctish.
(Thanks Pete H and Towy for the lone of their wheels)
Spookypt
  #33 (permalink)
Old 09-08-2015, 09:10 PM
Cobra Make, Engine: Manufactured by Me, 408 Windsor, TKO600, 3.3 Jag rear
Hi Matt,
By way of Clarification, I had to move my coilovers inboard on the rears so my tyres and wheels did not foul them. There already was another position on the bottom location point (ie further inboard) to connect them to. However, this meant they would foul on the chassis so I had to scallop one of the chassis bars to overcome this.
If this does not make sense will show you at the Nationals.
Serpnt
Melbourne
  #34 (permalink)
Old 09-08-2015, 09:35 PM
Yeah Theo that makes sense. Lets catch up at the Nats. Sounds good. Matt
  #35 (permalink)
Old 09-08-2015, 11:47 PM
I'm trying to achieve this sorta look......
boxhead likes this.
  #36 (permalink)
Old 09-09-2015, 03:52 AM
Theo just had a look and shocks are already set up as inboard. Hmmm. I'm looking forward to having a good look at yours. Bit of a bigger I'm not bringing mine for comparison but never mind.
I did chase up DSC for some set up advice but got no responses so I'm Robinson Crusoe sussing it out as I go. Next job is the Ac pulley once wheels are done. That set up is crying out for a decent solution. Matt
  #37 (permalink)
Old 09-09-2015, 08:00 AM
Aussie Mike's Avatar
From vague memory of looking at the chassis of one of these the shock mounts to the upper control arm. Is that the case with yours? It wouldn't be hard to modify the shock mount to bring the shock a little further inboard and give you the required clearance. I did that when I narrowed my rear end to make room potentially for a 12" wide rear rim (Only running 11" rears at the moment).
Mike Murphy
Melbourne Australia
  #38 (permalink)
Old 09-09-2015, 08:49 PM
On mine the shock mounts to the wheel hub and has 2 location points. We are dealing with millimetres so not a lot of flexibility.
As to DSC, my understanding is that they have had different wheel hubs so it mat be that ours are different Matt.
All will be revealed at the Nationals
Theo
Serpnt
Melbourne
  #39 (permalink)
Old 09-14-2015, 09:58 PM
Interesting development fyi...
Nitto NT01 tyres ARE NOT legal in Australia to be used on the street. Race tyre only despite the DOT claim. My tyre guy told me today about the issue when I enquired as to pricing and as a matter of curiosity I emailed another well known Sydney supplier to be told regarding my legality question that
"" They are DOT approved but stated on the tyre “RECOMMENED FOR COMPETITION USE ONLY” so best to check with an engineer or your local traffic authority in your state to confirm if they will allow you to run them on the street.""
Hmmm kind of long winded way to say NO don't you think? Buyer beware.
Spookypt
  #40 (permalink)
Old 09-14-2015, 10:53 PM
Modena's Avatar
if they're DOT approved then they're legal eh? "Recommended" means just that?
Do you know Rod Hadfield's Merlin powered '55 Chev? It's road legal in Victoria, but can't say I would recommend it for the street....or hmmm ok maybe I would
Ben in AU
