Like Tree92Likes
  #41 (permalink)
Old 11-29-2015, 12:48 PM
guye's Avatar
Another tip, Darryl. The front loop fuel line in front of the pump/filter in the trans tunnel made me nervous, with the tailshaft spin get close by. So I added an extra p-clamp to fix it down near the floor. Just being extra cautious I suppose.
All looking nice. The fuel tank is a bugger of a one-man job isn't it. You seem to have employed all the same ideas I did to manage it :-)
d488y2 likes this.
Guy
  #42 (permalink)
Old 11-29-2015, 03:42 PM
Looking great Daryl, that is one impressive looking motor.
You certainly cant fault the level of enthusiasm at Herrods for all things Ford. There actually pretty competive on pricing as well, compared to importing!
Are you drilling and tapping saddles for the lines your running or are they pre-drilled?
d488y2 likes this.
  #43 (permalink)
Old 11-29-2015, 10:59 PM
d488y2's Avatar
Cobra Make, Engine: Cobra Replica, 5.0 Supercharged Coyote
Guy, thanks for the fuel line tip, definitely worth look at.
Hoitly, the builder has to drill and tap all the holes for the brackets and clips, very easy to do, most of them I pre drill then use the drill on low speed to tap out the hole.
  #44 (permalink)
Old 11-30-2015, 02:17 AM
TheDoc's Avatar
Cobra Make, Engine: PACE427 under construction
I don't know how far back your motor will sit but it might be worth putting a spacer under that frontmost hardline bracket. My 351 is quite far back and its almost impossible to get a spanner on that hard line connection at the front with the engine in. If it sat a little more away from the chassis Id be ok.
  #45 (permalink)
Old 11-30-2015, 02:34 AM
leroy17's Avatar
Looking great, so clean, looks like all lines up and just looks....... Factory.
Never gets old looking at this, good work with heaps of pics, serves as a reference for many and just something to perv on for others.
  #46 (permalink)
Old 12-02-2015, 02:49 PM
d488y2's Avatar
One of the great joys of building a kit car is chasing parts. For my throttle control I went with a Lokar unit and pedal. With the pedal I only needed the arm. Once the pad was removed I found that the whole unit easy mated with the Tilton Pedal box. All I had to do was cut down the Tilton supplied throttle rod, adjust the accelerator pedal and the two became one. Job Done!
guye, boxhead, leroy17 and 3 others like this.
  #47 (permalink)
Old 12-04-2015, 03:25 AM
750hp's Avatar
Great solution!
Craig
  #48 (permalink)
Old 07-05-2017, 03:52 PM
d488y2's Avatar
It’s been a while since I’ve posted an update of my Build.
The Engine is In and the Body is back on.
Buzz, mate, LoBelly and 7 others like this.
  #49 (permalink)
Old 07-05-2017, 06:08 PM
Tonus72's Avatar
Cobra Make, Engine: ?????
I think I have said this before mate, but I frikkin' love that engine !!!
The road to hell is paved with good intentions
  #50 (permalink)
Old 03-02-2018, 02:53 AM
I see your point deano 59 ... yes it's nice to just assemble a car. I did that for years with Monogram, Tamiya and a lot of other models. I actually enjoy the challenge of modifying parts , designing and creating parts for my car. Making it all work under the ridiculous scrutiny of the RMS . The challenge of building something by yourself and for yourself is very satisfying ! Especially when somebody asks where you got that bit and you reply ..I made it myself.
Jaydee likes this.
  #51 (permalink)
Old 03-02-2018, 04:14 AM
Buzz's Avatar
Thumbs up
Same here - that is a mean looking powerplant! Really looking forward to reading the road test report when this build finally hits the pavement.
Tropical Buzz
