2Likes
Post By itempany
Post By 750hp
10-02-2015, 11:24 PM
WA
Cobra Make, Engine: GForce Boss Chassis, Jag suspension, Powerlock Diff, Boss 290 engine
Engine Number
Hi Folks,
I think I may have made a blunder. The engine is completely built and running very nicely now.
Only problem I have is that I didn't take note of the engine number while I was doing it.
The engine is a Boss 290 5.4L.
From what I remember, the engine number is stamped on a plate just behind and underneath the alternator which I now can't get at without disassembling a fair part of the engine.
I've got what I believe is the block number. It's along the lines of...
RF. 2C5E-XXXXX-XX
Can I use this to get the engine number? Is there anywhere else that I can get the engine number from?
Adam.
10-03-2015, 12:10 AM
qld
Cobra Make, Engine: Drb, 302 Comp cam, Cobra Nationals 2001 and 2002
Do you have one of the inspection cameras with flexible shaft. That might be a cheaper exercise than stripping some of the engine down?
10-03-2015, 12:22 AM
sa
i dont think you will get the engine number from that casting number did your engine builder write the engine number on your recite at all ? .
cheers dean
10-03-2015, 07:01 PM
WA
Engine number
Hi Guys. I got the engine from a wrecker. Unfortunately it doesn't have the engine number on it.
I do have a camera with scope though. I'll have a dig around and see if I can dig it out.
Thanks for the assist
Adam
10-03-2015, 08:33 PM
NSW
10-04-2015, 05:02 AM
Q
What's going to happen when an engineer / department of transport / safety certificate provider wants to verify the engine and VIN details? I wonder how this is managed in standard Falcons?
Craig
10-04-2015, 09:26 PM
NT
Engineer and MVR/RTA will want to sight the actual number stamped.
Cruising in 5th
10-04-2015, 11:29 PM
That is exactly correct.
If there are ancillaries on the engine that make it difficult to identify, then they need to be relocated for better access to read the number.
10-14-2015, 11:31 PM
WA
Rightyo
Okay... after a bit of messing around and the use of a camera on a bendy pole  I've now got the engine number.
I'm currently on the phone (on hold) to the DOT to ask them but I thought this might be a good alternative...
How do I go about getting a VIN now that I've got the engine number?
I've been through the DOT website and not really found anything applicable.
Adam.
10-20-2015, 01:18 AM
WA
That's what you get for not reading the instructions...
Okay, I've found the VIN form (funnily enough, sent to me ages ago and I hadn't been through all of the paperwork).
After speaking to a couple of exceptionally helpful people at the DOT, they've given me an email address to send the VIN form off to.
All done, now I'm just waiting. After that, it'll be onto temporary movement permits for weighing, wheel alignment, and final testing and engineer's check.
Thanks again for the help.
Adam.
