Like Tree4Likes
  • 4 Post By stiffy
Old 10-05-2015, 02:06 PM
stephen low's Avatar
Default Internal aerial
Guys
With my stereo coming to fruition, it made me think bout how to best get radio reception.
Clearly I'm looking for an internal antenna arrangement, what are my options?
I have a spot I can mount it into that tucks it under the dash immediately behind the firewall just needs some suggestions on type of aerial.
Cheers and thanks
Steve
slowy
Old 10-05-2015, 02:20 PM
letsboogie351's Avatar
Cobra Make, Engine: Kenmer with Ford Quad Cam Boss 260
Default Radio antenna
Steve,I just used a universal pillar mount. You can bend it to suit the shape of the hoop behind the dash. You can mount directly to the hoop and no-one can see the antenna
Doug
Aerpro Offset Pillar Universal Aerial Antenna AM FM Radio Suit CAR Truck AP120 | eBay
Old 10-05-2015, 03:44 PM
Thanks Dougie, that pic reminds me of a version of that aerial I had seen being fitted somewhere.
I did buy a short flexible style from Jaycar but whether it needed to be properly grounded I'm not sure.
But I certainly didn't get much more than static over the radio in my first short test.
Do aerials need grounding per se?
Steve
slowy
Old 10-05-2015, 11:02 PM
Krait's Avatar
Steve
Yep. Connecting it to the chassis should work. Ensure the connection is clean.
Geoff
Old 10-06-2015, 04:37 AM
renovationinnov's Avatar
slowly
I have an under dash unit that fits [ along side my wiper tubes ] that has to have a power supply to boost the reception works fine for me except in tunnel but what ariel does got it on line as[ remote radio ariel]
rob
Old 10-06-2015, 02:09 PM
Thanks Rob
Yes my target location is the same spot though fitting it now may be a bit tricky.
Am thinking of buying the aerial model that Dougie has pictured above as they can be had from Autobarn I believe.
I now recall the same style of aerial going into one off Marty's kits as where I'd seen this installation. The mast was extended and then gently curved to match the dash curve.
Not sure how that style of aerial will perform but I can only give it a try I guess.
slowy
Old 10-06-2015, 02:23 PM
Steve, it works well. Mine has been in that location now for a few years. Even on country journeys when the Melb. station fades just swap to the nearest country station.
Old 10-06-2015, 04:30 PM
Thanks Doug.
Pretty much sets the plan in stone then.
Between Autobarn and a visit to Blackmans tomorrow I'll have a few more project components under control (I hope)!
slowy
Old 10-07-2015, 07:43 PM
Default Radio
Slowly,
I think you are spending far too much time on the fittment of a stereo
with multiple speakers. The reception is poor at best with an under mount
antenna and the sound is poor with music due to the obvoius. I have had the
same CD in my Cobra for 6 years as the radio reception on AM is nonexistant
and I refuse to listen to FM crap.
Spend the money on a CAM and a set of side pipes, my 2 cents worth.
i.e. I didn't put one in the Daytona.
Stiffy
Old 10-08-2015, 05:16 AM
I know what you are saying Herr Stiffness, if it doesn't work so be it but it does give me blue tooth and other capabilities which might be useful too.
slowy
Old 10-11-2015, 12:15 PM
Cobra Make, Engine: Robnell Blown LS1
This is what I used.
Works just fine !!
www.tunetrapper.com
Hardest part is being able to hear the stereo over my open sidepipes
Old 10-11-2015, 01:14 PM
Thanks guys I went with Doug's option and it works fine.
Was a real ***** to retro fit under the dash and in front of all the gear mounted in there but I've managed and the aerial spans across almost all the dash width.
slowy
