Like Tree9Likes
  #21 (permalink)
Old 02-01-2016, 01:05 AM
Gav's Avatar
Gav Gav is offline
Originally Posted by Modena View Post
Im running Ferodos as recommended after discussions with Competition Friction. The braking in my car is AMAZING!!!
A little too amazing for my liking...
gjkrv8 likes this.
Powered by Cu
  #22 (permalink)
Old 02-01-2016, 02:08 AM
Modena's Avatar
and to think I ALMOST went with 18" wheels so I could go 343mm on the front.....should have done it.
gjkrv8 likes this.
Ben in AU
  #23 (permalink)
Old 02-01-2016, 02:37 AM
Tenrocca's Avatar
Originally Posted by RODA View Post
So I have decided to leave the brakes alone as I already run stainless flexible lines and at present run yellow stuff brake pads.
The tyres I am looking at are NItto Nt01, does anybody have any feed back on these tyres.
I am also going to do an advance driving course, I have read about John Bowe's course has anybody tried anyone else in Melbourne.
Thanks
Rod
Pretty sure they are a same compound as the R888 (read that somewhere) and nitto is owned by toyo. They are a proper R spec which is a step up from your KU36\NT05 etc
  #24 (permalink)
Old 02-01-2016, 03:06 PM
Rod I'd mentioned earlier on another forum topic that unfortunately the NT01's are only completely street legal in NT, WA and SA. They are deemed a competition tyre only in NSW, VIC and QLD due to there being no traditional load rating printed on the sidewall.
This is from Nitto Australia direct to me via email. There are retail sellers who will still sell them to you to use as a street tyre but the reputable ones won't.
  #25 (permalink)
Old 02-01-2016, 11:14 PM
RODA's Avatar
Cobra Make, Engine: Classic Revival LS1 6spd
Thanks Spookypt
I guess that counts them out.
I will have to keep searching for some KU36s then.
Thanks again for the heads up.
Rod
  #26 (permalink)
Old 02-01-2016, 11:52 PM
All good Rod that's what this forums all about.
What actual sizes are you after again?
As u know the NT05 isn't a true r spec. AO48 and the latter AO50 are a great tyre by expensive ish. Falken make a RT615 which are like the NT05 so no good either.
Matt
  #27 (permalink)
Old 02-02-2016, 01:10 AM
Aussie Mike's Avatar
We could probably fit 343s in there with some creative machining. Managed to squeeze them inside my 17" fronts. Probably overkill though.
Mike Murphy
Melbourne Australia
  #28 (permalink)
Old 02-03-2016, 03:17 AM
Towmaster's Avatar
I've got 375mm rotors inside 17" rims..... But not on the Cobra, only 343mm under her.
Rate This Thread:
