Like Tree1Likes
  • 1 Post By boxhead
Old 01-28-2016, 03:36 AM
snakesaway's Avatar
Cobra Make, Engine: Evans and Wooley, 302 Windsor, Supra turbo 5sp
Default Washer bottle mounting/heat shielding
Hi all,
Just curious what people have done with their washer bottle placement or some sort of heat shielding. The washer bottle is currently mounted on the front of the passenger side foot well. The problem is below this runs the exhaust to the side pipes. The washer bottle is a plastic universal job and what do know the plastic retainer for the washer motor has melted funnily enough. So the motor was just floating basically being held in place by the tube and wiring. The motor has also started leaking basically the heat has killed I think.
So I was wondering were people have mounted their washer bottles or what they have done about some heat shielding. My initial thoughts were to just fold up some ally plate as a heat shield to go below and up the sides of the bottle. I figured this should work.
Interested to know people thoughts and ideas i think the heat shielding is the easiest option but moving the bottle maybe a better long term solution.
See pictures for current location
engine_bay_sm - Club Cobra Photo Gallery
57_9_ - Club Cobra Photo Gallery
Andrew
Old 01-28-2016, 12:22 PM
renovationinnov's Avatar
andrew I had the same bottle & the heat did affect it so I got a copy in alloy of ebay that uses the same washer motor & now bizzinga
it was only $ 10 dearer
rob
Old 01-28-2016, 03:12 PM
Modena's Avatar
I am using an aluminium Aeroflow bottle, and mounted it in the front left corner of the engine bay, well away from any heat.
Ben in AU
Old 01-28-2016, 03:25 PM
boxhead's Avatar
Who needs a stinking washer bottle.
Modena likes this.
Cruising in 5th
Old 01-29-2016, 07:02 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I did not install a wasker bottle, got a pass from the state police when they inspected the car.
I did have to install two heat shields: Master cylinders and steering column.
These hang over the headers out from the head on the left side.
The top end was gone over by the NASCAR shop and they installed a .610 CAM. When they did that, I had a good jump in heat as well as HP. It was enough to tip the thermal tolerances.
So, the brakes began to fade and the steering began to stick.
I formed 1/8 aluminum in a firewall mounted bracket to shield the master cylinders and I made a rolled sleeve that is clamped to the steering column.
Both work as expected. I only wish I had design them in at the beginning.
Hope this helps.
Tru
Old 01-29-2016, 05:06 PM
Lexluther's Avatar
Stick it in the boot Andrew no heat problems in there
Old 01-30-2016, 09:59 PM
stephen low's Avatar
Perhaps you can start on the bling process.
I had this SS tank made and it hangs on the end of the passenger footwell.
Water pump sits on outboard side shielded from the heat by the tank itself.
You can see the water tank behind the last air intake elbow leading to the manifold on the right of the photo.
slowy
Last edited by stephen low; 01-30-2016 at 10:05 PM.. Reason: Granma and better pics
