November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree5Likes
  • 2 Post By mudbrick
  • 2 Post By snakesaway
  • 1 Post By albanycobra
Old 02-26-2016, 04:37 PM
Cobra Make, Engine: Homebush, 302 Windsor
Default Have to go LPG?
So here's the first of many questions.
I have an early 2000's 5.0 Windsor. Does this have any chance of passing NSW emission testing or should I be planning to convert to LPG?
Old 02-26-2016, 08:36 PM
Im running a 351w with efi. Will put the best "Kats" I can in, and a good tune.
Testing is to ADR 37/01 if I fail, plan B.......E85?
albanycobra and itempany like this.
I dont have a temper,I just react quickly to Bull*
Old 02-27-2016, 02:47 PM
snakesaway's Avatar
Cobra Make, Engine: Evans and Wooley, 302 Windsor, Supra turbo 5sp
Hi guys,
I have read on the forum somewhere I just can't find were but the cats in the current Holden/HSV are apparently very good I am sure I read they were Euro 5 rated which is more stringent that ADR 37/1 I believe.
Good luck
Andrew
boxhead and albanycobra like this.
Old 02-28-2016, 06:53 AM
albanycobra's Avatar
Yeah you can get an AU Falcon 5.0l to pass with good cats and a good tune. I will be doing the same with my Pace.
deano59 likes this.
Old 02-28-2016, 11:34 AM
Thanks Gents, that's good news.
Old 02-28-2016, 02:27 PM
Cobra Make, Engine: absolute pace chassis #50 L98 & 6 speed auto
my last cobra was straight lpg i felt the weight of the tank actually helped to settle the rear of the car down over bumpy roads ..i reckon wih injected lpg nowdays lpg would be a good option ..
a cobra is a passion anything else is just a car
i dont care what the question is .. The answer is more power!!!
Old 03-05-2016, 05:42 PM
Bryan Wilson's Avatar
Cobra Make, Engine: Real: Southern Roadcraft, SRV8, 351W stroker
Default LPG power
Get hold of REPTYL here on club cobra he has a very fast LPG powered car.
COB-66 Young at heart old fart.
Don't drive faster than your guardian angel can fly.
If it doesn't matter what gear your in you have enough torque.
VK3KDN
Old 03-06-2016, 04:31 AM
Cobra Make, Engine: v10 ford
Its a can of worms, that subject. Im in SA and my advice may not be worth a bumper in NSW, but here, if you were to run injection and a factory computer your engineer would do an idle sniffer test and you could pass if you have some good cats installed.
But if you need an IM240 test your car goes on a dyno and exhaust gasses are measured. The pass mark is not a high as new cars and many have had their car tuned to get the reqd readings. That depends on what type of ECU you have.
Lpg gas fitting is not emissions free and they could require you to have a 240 test anyway . Your engineer should be giving you all the requirements and regulations that he has to sign off on.
