Old 05-09-2016, 02:23 AM
Registered User
Default MotecM84 Coil packs and Cam/crank wiring
Hi All
I have a ford 5L from an AU falcon in Australia. I think it is a similar motor to the last ford Explorer motor from the US.
I'm also using a Motec M84 ECU.
It has the 4 coil packs which are 3 wire plugs so how do I wire them. Do I wire Ign 1 to run coils 1 and 2 then wire ign 2 to run 3 and 4 etc.
Both the cam and crank plugs are 2 wire plugs, so I am assuming they are magnetic sensors not Hall effect. So do I then wire these with only + and - wires and the shield to -ve with no sync or ref wires?
Any help appreciated.
Thanks in advance
Patto
