questions
- » Blogs
- » Image Gallery
million posts!
| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
22Likes
05-16-2016, 07:29 AM
wa
I set my pushrod length at 50% valve lift at cam and the rocker at 90deg to the push rod for a starting point.
05-16-2016, 07:37 AM
VIC
I think I must have been typing ... looks like we've both used the same
method.
LB
05-16-2016, 06:36 PM
QLD
Just to clarify, is it not the valve head that has snapped off, which happens from piston contact.
The valve stem has snapped just under the valve collets from side loading, from the rocker arm pushing the retainer at early valve lift.
That would be a rare failure, but it shows the strength of your collets and retainer.
I would hope all of the valves were inspected for this condition.
Now this time, with the light spring fitted, every clearance needs to be checked, valve to piston clearance, retainer to rocker, rocker to stud etc, throughout the full 4 stroke cycle of the engine.
Gary
05-16-2016, 06:43 PM
Senior CC Premier Member
CA
I just hope you can find all those pesky little metal parts that went somewhere when it broke!
05-16-2016, 07:34 AM
VIC
Glad you got it sorted Michael. Is the piston OK?
Mike Murphy
Melbourne Australia
05-16-2016, 07:47 AM
VIC
I think so - I stared at it for ages and it held together
It looked to me like I was very fortunate with the timing of the valve drop and it appeared that the valve had just knocked the carbon off the piston.
... stand by for my future thread on a broken piston and conrod through the block
LB
05-16-2016, 04:50 PM
NT
Good stuff LB.
Have you measured the old pushrods to see what length they are?
Cruising in 5th
05-16-2016, 05:20 PM
VIC
Originally Posted by boxhead
Good stuff LB.
Going from memory 6.250" - which I think is standard length
ta
LoBelly
05-17-2016, 06:28 AM
VIC
On with the show
here is the recovered valve
Gaz - and some of the less eagle eyed amongst you - will notice a harmonic balancer sitting on the bench behind the ex-valves.
And you may notice that in Post #28 there is a ratchet attached to the crank bolt. Its a very convenient way of turning over the engine as you check all sorts of stuff and as you re-assemble the engine and set stuff up.
And after 4 months it may transpire that you finally have all the bits and pieces you need and can (and do) re-assemble your engine and fire it up.
Stopping to recharge the battery because it seems to have difficulty turning over...
Only to look down at the front of the engine when you're trying to set the idle and notice your ratchet is now hard up against the chassis and appears to have wisps of smoke coming off it
05-17-2016, 07:21 PM
QLD
Wow, look at the bend in the valve stem.
Sheared off straight under the valve collets.
Thank god the piston is ok.
Can you see what I mentioned about the lifter for that valve in one of your early photos?
Or is what I see an illusion?
Gary
05-17-2016, 07:46 PM
CA
Again, did you find the rest of it somewhere in the engine?
05-17-2016, 10:47 PM
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Can't believe the silly string valve pic! Holy moly.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
