Like Tree3Likes
  • 1 Post By Cobrakiller
  • 2 Post By ICCARS
Old 09-06-2016, 01:51 PM
leroy17's Avatar
Default Caster / camber gauge
Does anyone have a caster camber gauge which they are prepared to lend or hire out.
Will pay for postage and so on.
Cheers.
Old 09-06-2016, 02:29 PM
Try Ozvenom mate
Old 09-06-2016, 03:56 PM
leroy17's Avatar
Thanks Matt.
Old 09-06-2016, 11:35 PM
i bought a cheapie one that lives in the tool box we take to the track . only gets used if we bend a strut or have to change one i think it was about 50 bucks from china
Old 01-10-2017, 02:39 AM
My engineer drove my CR for the first time , and it doesn't want to correct itself into a straight line. He suggests about 7 degrees of caster, Is that going to make steering when parking much heavier, is it necessary, and is that to much caster?
Thanks.
JD
Old 01-10-2017, 04:13 AM
leroy17's Avatar
My set up was welded in on the weekend and running around 7 and this was suggested by WRS. They set my previous one up and for memory it was 6.5 and it was great to drive, self centred , and, well get a few more arm muscles and parking is no worries.
Old 01-11-2017, 07:49 PM
Cobrakiller's Avatar
The more positive castor you add the more the self centering effect on the steering in a straight line. This also increases the effort needed at the wheel.7+ castor is fairly normal setup on modern steering systems with power steering. Check what castor you have now and increase this until you get the right feel.Any adjustment will also effect your camber too, steering geometry is a compromise.
Jaydee likes this.
Old 01-12-2017, 09:57 PM
ICCARS's Avatar
Cobra Make, Engine: AC Cobra - ICCARS 001, 4.2LTwin Turbo, AWD, 5 speed tiptronic under construction
I would be inclined to adjust the positive castor to no more than 6 degrees on a manual steer car, around -1 degree camber and depending on your front wheel width, anything over a 225 wide tyre use 3mm toe in per side.. This will give you a really good staring point for you to assess the feel on the road.
leroy17 and Jaydee like this.
Wil Escabache
ICCARS AC Cobra 001 (AWD) U/C
RF 098 GT40 Twin Turbo
ICCARS GT40 - U/C
www.iccars.net
