Like Tree11Likes
  • 3 Post By Aussie Mike
  • 1 Post By stephen low
  • 4 Post By gjkrv8
  • 2 Post By boxhead
  • 1 Post By snakesaway
Old 02-22-2017, 01:00 PM
snakesaway's Avatar
Cobra Make, Engine: Evans and Wooley, 302 Windsor, Supra turbo 5sp
Default Squeak from rear of car.
Hi all,
I have weird squeak coming from the rear of the car when I first start driving. the squeak increases in frequency as I increase speed, and it goes away or is masked by louder road noise as I increase speed. It sounds like rotational noise/wheel bearings as opposed to a squeaky bush or suspension squeak. I haven't noticed it as I pull up to or away from lights. It appears to go away with driving but if the car is left sitting for say an hour the noise will come back again, when the car is first moved in either forward or reverse.
Has anyone had similar problems? If it is wheel bearings are they easy to change I have had a look on the net and it looks relatively easy its just measuring the float/pre load that might be tricky.
Andrew
Old 02-22-2017, 03:41 PM
Gav's Avatar
Gav Gav is offline
id get under the car and start looking for something obvious.
Could be a uni, a CV joint or a bearing.
Powered by Cu
Old 02-22-2017, 04:07 PM
Aussie Mike's Avatar
Brake pads dragging?
Gav, DaveW and Rog246 like this.
Mike Murphy
Melbourne Australia
Old 02-22-2017, 04:11 PM
boxhead's Avatar
What rear end does your car run?
Cruising in 5th
Old 02-22-2017, 04:42 PM
snakesaway's Avatar
Ah yes that would help its Jag IRS series 1?
Old 02-22-2017, 08:11 PM
stephen low's Avatar
Yep I've XJ series II rear and think I've a similiar issue.
Tried removing pads, cleaning pad retaining rods etc with no luck.
Permanent fix will be the X308 parts to transform the rear to outboard discs and a better system.
Temporary fix is to turn up the volume on my stereo!!!
Sorry not really helpful other than it is a right beeitch to get in and have a go at fixing those inboard discs to no effect.
ICCARS likes this.
slowy
Old 02-22-2017, 08:14 PM
ICCARS's Avatar
Cobra Make, Engine: AC Cobra - ICCARS 001, 4.2LTwin Turbo, AWD, 5 speed tiptronic under construction
I would check your universal joints in your tailshaft first, see if there is any play there, then wheel bearings second.
Wil Escabache
ICCARS AC Cobra 001 (AWD) U/C
RF 098 GT40 Twin Turbo
ICCARS GT40 - U/C
www.iccars.net
Old 02-22-2017, 10:52 PM
gjkrv8's Avatar
Maybe put it on jack stands and turn the wheels and see if you can find the source of the noise.
I had a squeak too and it turned out to the the stone shield for the rear disc rotors had been bent and was just touching the rotors. Sounded like a dry bearing squeak noise.
Hope you find it and it turns out to be a simple fix. Cheers Gregg
boxhead, Gav, DaveW and 1 others like this.
Old 02-23-2017, 12:14 AM
boxhead's Avatar
Do as Gregg has said, Only thing I would add is do it with a mate, get him to hold one wheel from spinning, and you turn the other wheel.
Doing this will make your wheel turn and the tailshaft.
no noise then swap sides and repeat to find the noise.
You may want to jack it up and support under the outer bearing carrier so you have the driveline in its normally running alignment, rather than drooping.
Gav and DaveW like this.
Cruising in 5th
Old 02-23-2017, 10:26 AM
snakesaway's Avatar
Thanks for the suggestions I am on holidays for the next 3 weeks so I will see what I find hopefully something simple.
boxhead likes this.
Old 02-23-2017, 04:42 PM
renovationinnov's Avatar
I have the same rear end as yours
& had the same noises
change pads to a medium compound & that solved mine [ took awhile to find but ]
had to hard compound pads
Old 02-27-2017, 03:02 PM
dhs.buckley's Avatar
Cobra Make, Engine: Python ford 302 ho, 4 speed toploader, jag irs 3.54
Check if brakes, but if not, when the wheel is off the big aluminium section wheel bearing holder has a grease filler at the top. check that its full of grease as even from new these never had enough grease in them.
