Like Tree4Likes
  • 1 Post By Tenrocca
  • 1 Post By renovationinnov
  • 2 Post By Owell
Old 04-27-2017, 05:18 PM
Cobra Make, Engine: Classic Revival, 3211,6.2,TKO600
Default Engine cutting out
G'day,
I've had trouble with my LS3 cutting out on me. It happens if I accelerate hard, also when I hit a bump it cuts out. I have to turn the key off and restart.
A real problem when it happens.
If anyone could help much appreciated.
Thanks Mark
Old 04-27-2017, 07:14 PM
Dimis's Avatar
Could be one of a few things.
The fact you say under hard acceleration has me thinking fuel supply issue.
I'm no expert but I'd start with checking loose wiring starting with the fuel pump, right through to the injectors?
Best of luck
Old 04-27-2017, 07:58 PM
Tenrocca's Avatar
I had something similar with mine - the main feed from the battery to the fuse box had fried at a join. Wasnt so much happening at bumps etc, but was intermittent. Definitely sounds like a loose connection somewhere.
boxhead likes this.
Old 04-27-2017, 09:44 PM
Cobra Make, Engine: Classic Revival CR3510 L98
hi owell
I had a similar issue and had an accelerator wiring clip which was not clipped together properly and was separating when turning left and when my foot brushed the low hanging loom. Problem fixed when the fly by wire accelerator was clipped in to the loom properly. this also meant the car would not start when the accelerator was not being seen by the ECU.
Hope it might help.
Scooby
Old 04-27-2017, 10:59 PM
No sympathy at all !!
Serves you right for going over to the dark side
Rog 246
Harrison #100
Old 04-28-2017, 12:17 AM
renovationinnov's Avatar
I'm with DIMIS
check for loose connections & earths
harsh rog 246 now come to the light [ LS LIGHT SIDE]
Rog246 likes this.
Old 04-29-2017, 03:10 AM
Thanks for the advice. You've given me a few things to check out.
Rog246 I made the mistake of saying it was an LS engine. You didn't point out that's why I'm having problems. HaHa
Mark
Rog246 and renovationinnov like this.
Old 04-29-2017, 08:43 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Are you bloody serious - a forking chevy???
Sounds like a loose ground.
Tru
