November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree3Likes
  • 1 Post By Dimis
  • 1 Post By ICCARS
  • 1 Post By SydneyChris
Old 06-28-2017, 04:34 AM
Default 7" headlight rings
Was looking without much joy so far for a pair of chrome headlight trim rings to suit my 7" LED's.
Appreciate any leads..
With thanks
Chris
FFR Coupe 65
LS3 motor, TR6060 box with Falcon ABS, 17" Halibrand wheels, 3.55:1 Ford Racing IRS and Willwood brake upgrade
Old 06-28-2017, 05:50 AM
Dimis's Avatar
Try oz mini spares.
They also have stainless if you prefer.
500929 - Mini headlamp rim chrome on steel genuine rover
Shame your not in Melb I have a couple off the car for you to try before you buy.
In any case they're not overly expensive.
Best wishes I hope they work out for you.
SydneyChris likes this.
Old 06-28-2017, 07:04 PM
boxhead's Avatar
Best to figure out which ones your kit requires.
Some use Mini, some use MG (they are different)
Cruising in 5th
Old 06-29-2017, 04:12 AM
thanks gents.. found some Hella trim rings also... their buckets appear relatively similar to the whitevision lights I have... hard to avoid a bit of trial and error on this one unfortunately..
FFR Coupe 65
Old 07-07-2017, 06:02 PM
Whitevision are trying a couple of types out.. the mini ones look more likely, as there is a threaded tab on the bucket for a retaining screw.. will update when I have an outcome.
FFR Coupe 65
Old 07-07-2017, 06:09 PM
ICCARS's Avatar
Cobra Make, Engine: AC Cobra - ICCARS 001, 4.2LTwin Turbo, AWD, 5 speed tiptronic under construction
Chris, we use the Morris 7" light trims as they have a nice taper in them and so not look as "bug eyed" as the standard parallel trims. Also try Midget & Sprite trims. Can get them off Ebay for a song.
Wil Escabache
ICCARS AC Cobra 001 (AWD) U/C
RF 098 GT40 Twin Turbo
ICCARS GT40 - U/C
www.iccars.net
Old 07-08-2017, 06:45 PM
ok.. thanks Will.. they were looking the most likely option, was just waiting to hear back from Whitevision if they managed to get a couple of different types to test on their particular headlight buckets..
FFR Coupe 65
Old 07-11-2017, 04:51 AM
Nothing back from the headlight supplier as yet.. Have a set of morris 7" rings on the way from the UK.. 9 pounds each plus freight.. will see how they go ..
ICCARS likes this.
FFR Coupe 65
Old 07-13-2017, 12:51 AM
ok... have the response from Whitevision... the headlight buckets they use are the Hella 1016 which match with the Hella 1017 chrome rings.
Will see if the Morris rings fit and go from there.
FFR Coupe 65
