Like Tree7Likes
  • 1 Post By johnc427
  • 5 Post By Wazza
  • 1 Post By Dwight
Old 07-14-2017, 04:25 PM
Tenrocca's Avatar
Default Dynamat - Does it make a difference in a cobra?
Looking at re-doing the carpets - the el cheapo stretchy speaker box stuff in there at the moment has lasted pretty well but it was only a temporary job at the time.
I see a lot of people put dynamat (or equvalent), and I have search for an answer but does it actually make a difference in a cobra? I would have thought all the other noises that dynamat cant mask would be much louder than the ones it does.
Old 07-14-2017, 05:40 PM
Cobra Make, Engine: Dax
Isn't there another product out there you can put on with a brush to match your paint?
Old 07-14-2017, 05:55 PM
Cobra Make, Engine: FFR MKII
Thumbs up dynamat
hello, I have a 1937 ford coupe and before I did the inside with dynnamat, you could hardly hear anything. once I dynamatted the floor and firewall my wife and I could actually have a conversation while we were driving 70+ on the freeway. around town is great. I cant speak for it in the cobra, but in the street rod it is a must. I experienced the same thing in my 49 ford pickup. I highly recommend it. I do have a factory five and not sure if it has been sound deadened or not. Hope this helps.
Auswallaby likes this.
Old 07-14-2017, 06:41 PM
stephen low's Avatar
I think for sound deadening in a cobra, the improvements will only be marginal.
I used a local equivalent for heat shielding and it has been very effective in this respect but I can hear the whining diff still very well - lol.
Hence the good stereo to drown out other ambient noises with music!
slowy
Old 07-14-2017, 06:47 PM
Cobra Make, Engine: Contemporary Cobra
Default Sound deading
It was a hudge difference! Car was much quiter, no noise from the trunk and the big perk was it wasn't as hot in the footwells...go for it!!
Jon
The Impossible Only Takes A Little Longer
Old 07-14-2017, 06:58 PM
venum14's Avatar
Cobra Make, Engine: Bennett Cobra
Great stuff and worth the cost. All my interior panels are aluminum, I drove the car with and without Dynamat before installing the carpeting...The Dynamat knocks down the noise and heat, then the carpet seals the deal!
Jeff
Old 07-14-2017, 07:58 PM
I found it to really quiet down the road noise. From my reading, I found it is designed to dampen vibrations and tones from the metal to metal contacts and inherent movement of body parts where they meet. IMHO, it does that very well. There are cheaper products available that are supposed to do the same thing, but after reading the reviews, I went with the Dynamat.
Bob
Old 07-15-2017, 12:41 AM
Wazza's Avatar
IMHO......It makes ALL the difference.
I "Dynamatted' the Sh*t out of my car when it was built.
Every surface inside, and UNDER the car...inside door panels.....and double thickness in some places( Floor panels etc.)
Turns Aluminium panels from drums into solid surfaces.
When you knock on every panel,and surface, it sounds like you're knocking on hard wood.
When I shut my doors, I recon they sound like a REAL car door shutting....not that usual hollow sound the Cobras often make.
Love the stuff.
Somewhere under there , there's about 30 kg of dynamat...
Warren
Old 07-15-2017, 01:27 AM
Cobra Make, Engine: Robnell Blown LS1
I used a local product on my Cobra.
As others have said.. Hard to tell if it makes a big difference but I like to think so. Even if only for the insulation against heat.
Resomat Premium | Tru-Fit Carpets
Old 07-15-2017, 05:12 AM
Dwight's Avatar
Smile
I used Dyno Mat in several cars. Great stuff
Found the same material on Ebay called Fat Mat Sound Deader for a lot less money. Same thickness and appears to be the same material.
Rog246 likes this.
Old 07-16-2017, 01:44 AM
Tenrocca's Avatar
righto - I'm convinced. How much do I need to do a cobra cockpit?
Old 07-16-2017, 02:26 PM
Dwight's Avatar
Smile
depends on what you want to cover.
Firewall
floor
tranny tunnel
rear bulk head
Just measure the area.
Old 07-17-2017, 08:14 AM
Cobra Make, Engine: UCC, Stroker 347
I just bought the 9 pc kit (9 pieces 18"x32") I will let you know how far it goes!!! May end up buying more, but this is a good start.
