12Likes
Post By BJ's Snake
Post By BJ's Snake
2
Post By DanEC
Post By Buzz
3
Post By Cobra #3170
4
Post By DaveW
08-19-2017, 05:12 PM
Vic
Radiator wind deflector ..wing...thingy ?
Hi All,
Sorry couldnt post a pic, but if you have a look at some web pics of original 427 street cars, like Bruce Camberns CSX3170 as an example, there is a horizontal panel in the center of the radiator opening.
Looking at other originals, some times this panel is angled up suggesting that it is a deflector.
Does any body know more info about these ? was it to reduce flow to the radiator for cooler climates or direct air to some other vent purpose ?
How was it adjusted ?
cheers to all
Dave
08-19-2017, 09:59 PM
NSW
I've always liked the look of the splitter in the nose Dave.
Don't know the purpose of it but looks good anyway!
289 FIA Cobras RULE!
08-19-2017, 10:27 PM
Vic
That's awesome BJ, is yours a panel, or a tube, hard to tell from the pics but yes, like the look as well.
08-19-2017, 11:58 PM
NSW
Panel in the shape of a wing,radius at the front to a point at the rear, about 100mm wide.
08-20-2017, 04:24 AM
My ERA's re-creation is also wing shaped and it's fixed in position. Seems the exact purpose and effectiveness of the originals has been debated forever. They don't seem to have any effect on engine cooling I'm told. Having an airplane wing in the nose would not seem to be the thing for ground hugging aerodynamics. Since the Street Roadsters were not intended to have an oil cooler maybe it was thought to help direct the air from that lower opening back towards the radiator instead of it moving up along the line of the radiator slope or something. However the area of the oil cooler is blocked off by a panel on my car - not sure about the originals.
08-20-2017, 04:31 AM
WI
My guess has always been that the originals' radiators slope backwards at a fairly significant angle and the splitter was intended to deflect the flow of incoming air so it entered the radiator perpendicular to its surface for less turbulence and better flow through the fins.
Tropical Buzz
08-20-2017, 04:03 PM
In which case the splitter would have been angled downwards?
Don.
08-20-2017, 06:14 PM
Cobra Make, Engine: G Force Cobra 347 stroker
Hi guys. if you have a radiator that stands straight up. With the grill opening lower compared to the total heigh of the radiator. The air is mainly directed to the lower portion of the radiator. If you have a plate that splits the grille opening and is mounted on the inner end in the middle of the radiator. It will split the air evenly over the radiator surface. As you know the hot water enters the radiator at the top. With more air directed to the top of the radiator. This can help cooling. This also helps when you have a doubble pass radiator.
If the splitter plate angles upwards at the radiator and the air flows well through the core. The flow over the splitter can increase downforce very slightly.
Competition radiators made by PWR can be made with the fins in the radiator on an angle. That way if the radiator is tilted back on the same angle, the air will flow straight through the fins without causing uplift.
Bender
08-20-2017, 08:54 PM
Front down force, I have tried it with and without and the nose stays down with the panel installed. Very noticeable above 150.
08-20-2017, 09:58 PM
Vic
oooh, Bruce, i'm a big fan of you and your car, its my screen saver actually  , yes even from downunder in Oz !
Would you have any pics of the splitter and how it adjusts?
cheers
Dave
08-21-2017, 07:22 AM
Well that's an interesting first-hand experience report. Wonder why they didn't also use it on the SC and competition models then?
08-24-2017, 05:29 AM
NSW
My radiator leans forward at a good angle so I made the number plate to lay down at speed (60 k ) and stand up when stopped. Damn plate reader cameras have stymied this for me.
08-24-2017, 07:40 PM
Nose splitter
I asked Dick Smith and he said it was not homologated with the car and they could not use it but they wanted to. I was told by an AC guy from England that I was crazy for not running it because of the down force. I tried it at SAAC at Watkins Glen in the early 1990's. I was up around 165 before the bus stop and the car was very stable at that speed. I took it out right after I bought the car in 1965 because I thought it was ugly. I stored it until the Watkins Glen event and reinstalled it after repainting the car. It has been in ever since, there is no adjustment just two tabs that hold it in place. The car had lots of lift above 140 without it so I was pleasantly surprised. There are pictures of it in my photo gallery.
08-25-2017, 12:35 AM
I was wondering how my 289 FIA would do at around 150-160. It will be a crowded field at Watkins Glen with right now 49 cars in my group. Depending how things open up, I may or may not be able to get up to about 150 on the back straight prior to the bus stop. should be able to get to at least 140. The nose opening is a little smaller on the 289 FIA, not sure how much of an affect that may have. Will let you now in a week and a half.
08-25-2017, 07:37 AM
Where can I get radiator wind deflector?
08-25-2017, 08:53 AM
Senile Club Cobra Member
rick@autoventureusa.net
08-25-2017, 03:49 PM
NSW
I formed the shape out of hard foam material and then fibreglassed, came up a treat!
08-25-2017, 05:20 PM
Vic
I suspect an aluminium louver will disappear from the back veranda
