Like Tree1Likes
  • 1 Post By 14adrnln
Old 09-06-2017, 08:40 PM
14adrnln's Avatar
Cobra Make, Engine: Pace427 Alumina #69
Default Wheel arch liner reccomendation for Alloy body
I am at the stage of getting my Pace427 Alumina body finished and ready for a test run but I really would like to line the inside wheel arches with some type of protective material to stop stones and debris from denting the panels from the inside. I had spotted a couple cars in the AP factory that had a high density foam glued to the inside of the arches. Does anyone know what thickness and how much I would approximately need to do all 4 wheell arches?
Scott
1985 CCX likes this.
Old 09-07-2017, 07:36 AM
HI Cobra's Avatar
You can double check with Kirkham as to the size and quantity, but I got 6' x 5' sheet of 3/8 foam from the recommended manufacturer for about $30. That
should be more than enough.
Flip
Old 09-09-2017, 05:55 AM
Neutral
www.haloefx.com.au it's a spray on / peel off coating. reasonably thick . have a look.
Old 09-09-2017, 06:07 AM
Phx Mike's Avatar
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
Agree that the stuff Kirkham uses works great. Not sure where to buy it but they will know..
Old 09-16-2017, 03:59 PM
Cobra Make, Engine: G Force Cobra 347 stroker
3m make an impact resistant tape. Its was a bit expensive last time I purchased some but your car looks worth it. The tape was originally designed to protect the leading edge of helicopter blades. It is a clear plastic film that sticks well to a clean dry surface. I have used it on race cars with great success.
Bender
Old 09-17-2017, 07:04 PM
14adrnln's Avatar
I have opted for some 6mm EVA high density foam which I sourced from Clark Rubber. I wanted to use something that will absorb the impact of the those larger sharp stones (you know the ones that flick up when you have brand new tyre tread). I think the 6mm EVA and Sikaflex should work great.
Thanks for all the advice guys.
Scott
