Like Tree11Likes
Old 02-13-2019, 03:58 AM
jcraigau's Avatar
When I had my Commodore tuned they set the speed to "exact" so 60 is 60, 110 is 110.
Old 02-13-2019, 02:37 PM
Gaz64's Avatar
So you had new rear tyres fitted before the tune?
Old 02-13-2019, 04:12 PM
jcraigau's Avatar
new ish...
Old 02-13-2019, 05:14 PM
I had a cop tell me once, that ignorance is no excuse for breaking the law. Lol.
JD
Old 02-13-2019, 08:13 PM
Modena's Avatar
You don't see many speed cameras in underground car parks :-)
you sure do in tunnels....
deano59, Gaz64 and Zedn like this.
Ben in AU
Old 02-15-2019, 03:15 PM
Cobra Make, Engine: Evans chassis, jag fr. & rear.
Jaydee
On a couple of AU Falcons I've played with and had transmission issues I found that:
One would start and drive normally when cold. Whether I drove 10-15 minutes to the local pub or forty minutes to town. Stop the vehicle for a period of time and it would go into limp mode. Third gear only on restart.
I put a scan tool on it which showed live data. The solenoid valves weren't operating.
I pulled the round input plugs off the trans. cleaned out all the debris and that fixed it.
The second issue was a constant change from third to forth and back (constantly) when cruising at about 90km/h. The scan tool showed tps out of range. Changed that and problem gone.
Both these vehicles are six cylinder models with a smaller but similar trans.
I know this isn't your issue but it might help you a bit.
Dave
Old 02-19-2019, 01:22 AM
It's actually starting of in second and shifting roughly to third. In the donor car it also shifted roughly to third. I changed one of the solenoids. I can't remember which one. It won't accept a scan tool. Only by connecting 2 pins together will it show a flashing code on the dash which is now not there. I think I have had trouble selling the car mainly because it's a Auto. I also want a manual now. As I'm moving to a better place I might drive it more.
JD
Old 02-19-2019, 03:21 AM
Mrs flatchat's Avatar
Wink
Yes! a manual -- focus emanual its a manual, manwel ?
Old 02-19-2019, 10:39 PM
we im hoping i dont have any of the problems you have had with your auto. i am hoping the 6 speed auto with tiptronic should shift faster up and down than you guys with a stick . time will tell..mind you i have no choice my lower left leg hardly works or moves so i had no say it it really auto or nothing im afraid ..
Old 02-28-2019, 01:21 AM
Gav's Avatar
Gav Gav is offline
An auto is definitely quicker off the line, my old car was awesome when you were giving it stick, but was a but dull on the street.
Powered by Cu
