November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree8Likes
  • 2 Post By xb-60
  • 1 Post By lnfletcher
  • 2 Post By willandrache
  • 1 Post By AC Hara
Old 02-19-2020, 03:59 PM
Cobra Make, Engine: RCM 2011 6.0l
Default Bonnet Gas Struts
Hi all I'm new to the AC group and looking to upgrade by bonnet and boot gas struts. Does anyone know the weight of a fibreglass bonnet and boot and also does anyone recommend any gas struts?
Thanks
Old 02-20-2020, 06:19 PM
xb-60's Avatar
Hi, and welcome.
The gas struts I have for bonnet/hood and boot/trunk are 200mm long extended, and around 125mm closed. They work very well at holding up the bonnet, and it would have to be a wild gust of wind to affect them. They don't have a brand on them unfortunately.
Here's a picture...
Rob. Smith and COL110 like this.
Old 02-21-2020, 06:08 AM
lnfletcher's Avatar
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
I used (2) 20lb struts on mine. Keep in mind that you are not lifting the hole "bonnet" but holding it open at whatever angle you end up with. IMO you don't want it to lift it when not latched.
COL110 likes this.
Old 02-21-2020, 02:35 PM
Cobra Make, Engine: Classic Revival
hi, I recently purchased some off ebay for my build. They have listings with different lengths and force (nm if metric). I found some that have the ability to adjust the force. i.e. let the gas out, with a supplied allen key. I didn't want the bonnet and boot lid to fly up when opened. They were only about $29 (AUS) a pair. If you get these, make sure you let the gas out only a smidgen at a time. Once it's out you can't put it back.
AC Hara and COL110 like this.
Old 02-24-2020, 09:06 PM
Thanks guys. Can you send me the ones you got off ebay so I can check if it works on mine.
COL110 likes this.
Old 02-24-2020, 10:52 PM
202355394418 this is the ebay item number.
