November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 01-19-2022, 05:08 PM
byroncobra's Avatar
Default Wiring Advice
¹Hi All
I'm picking up where the last guy left off... no electrics done to date other than the ecu rehash by an unknown sparky. Its an automatic trans and I'm scratching my head on a few connections. Can someone here enlighten me with what inhibit, TLC (or is it TCC) and the two reverse plugs may mean (I assume one to reverse light)
Now I need to remember how to add pics...
Thanks
[IMG]http://[url=http://www.clubcobra.com/photopost/showphoto.php/photo/90435
Greg
Old 01-19-2022, 10:12 PM
Gaz64's Avatar
Can you attach your photo please Greg?
Gary
Old 01-19-2022, 10:39 PM
Gaz64's Avatar
Is this your photo?
Gary
Old 01-20-2022, 04:20 AM
Cobra Make, Engine: My Build Venom kit - LS1
Hi Greg,
What engine are you asking about
Old 01-21-2022, 10:14 PM
Cobra Make, Engine: G-Force with LS1
Hi Greg,
I've just finished wiring up my LS1/4L60E. I'll try to answer you based on this engine:
TCC: sounds like one of the signals associated with cruise control. If you're not using cruise control, you don't need to worry about it.
Reverse: is the reverse signal coming out of the ECU. Normally you would use it to drive the reverse light relay. (I'm picking up the reverse signal from the gear select switch on the transmission, so I don't use the ECU signal.)
INH: got no idea what this is. Can you trace it back to the ECU to find out which pin it is connected to?
RPM: this signal should go to your tacho
F/PU?+ : can you clarify the exact name of this signal, it seems to be smugged on the photo. (could be the + supply for the fuel pump relay)
O2 + IGN: do you have heated (4 wire) oxygen sensors? This could be the positive supply to the oxygen sensors. Normally when the engine is first started, the heater element in the oxygen sensors are turned on so that they come up to temperature quicker, and therefore the fuel system can go into closed loop faster
ECU BAT+ : Assuming this is an input to the ECU, it should be connected to the Battery + terminal (through a fuse).
ECU IGN + : Assuming this is an input to the ECU, it should be connected to positive through the ignition switch (ie switch to + when ignition is in the ON or start positions)
Greg
Old 01-22-2022, 04:03 AM
Gaz64's Avatar
Originally Posted by gcarm View Post
Hi Greg,
Greg
TCC will be Torque Convertor Clutch. INH will be Inhibitor switch (neutral start switch).
Both connectors are 8 way, and only one side is labeled in the photo.
I uploaded that photo from Greg's pics, so I guess wait until he replies now.
Gary
Gary
Old 06-11-2023, 04:55 AM
Cobra Make, Engine: Shamrock
Did you come right with this? I didn't see (or couldn't decipher) throttle position or shifter position indicated on your plug set which seems odd. I installed a 4L60E some time back so know the drill.
