Old 10-14-2002, 05:29 AM
347's Avatar
347 347 is offline
Cobra Make, Engine: .
Default rpm
i have quad 44 mm idf webers on my 347,does anybody have an opinion about where/what rpm the engine would slow/stop reving and makeing power??
Old 10-14-2002, 04:05 PM
Jeff Frigo's Avatar
Depends on the cam. Give us the specs. and we can get pretty close.
Jeff
Mark Donahue
Old 10-14-2002, 04:13 PM
347's Avatar
347 347 is offline
cam specs: comp cams 294s,294 adv,248 @.050,560lift,110 lobes,
Old 10-14-2002, 04:14 PM
347's Avatar
347 347 is offline
i forgot its a solid flat tappet
Old 10-15-2002, 03:36 AM
750hp's Avatar
Lots more details would make the guesses closer to the mark.
Cylinder head flow numbers, valvetrain specs (Rocker ratio, valve spring pressure), exhaust header diameter and length, exhaust system diameter, ignition system, ram tube length, compression.
Old 10-16-2002, 02:20 AM
347's Avatar
347 347 is offline
ok here is what i know:int 298 @.600.309 @.700,exh 200 @.600,209@. 700,rocker ratio 1.6, 1 3/4 headers 4 into 1,40inches long,duel 2.5 inch pipes ,accel dizzy,crane ps91 coil ,hi 6 box,no ram tubes (k&n filters)comp 10.18.1
