January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
  #21 (permalink)
Old 06-24-2003, 01:24 PM
Cobra Make, Engine: Everett-Morrison, 434 cid
Originally posted by Mr.Fixit
So do you think the best approximation for one particular car, would be to do the electric spin up test at the same accell rate that the car's motor is able to accel the car in that particular gear? Your RPM/time in fourth gear in the quarter mile, used as the baseline accel rate for the electric motor's spin-up test with the tranny in fourth gear.
I think the losses would increase, the quicker you attempt to spin-up the drivetrain. But probubly not too greatly. Just theorizing here.
In my case the best approximation would be to take it to a chassis dyno and then caclulate the difference between the engine dyno. That electric motor stuff sounds like too much work
Actually, I don't care too much about peak power. Since I use my engines across a fairly wide rpm range I'm interested in AVERAGE power for the intended range; say 3500-7500 or 4500-8500. But, mostly I'm concerned with DRIVABILITY.
  #22 (permalink)
Old 06-24-2003, 01:30 PM
Mr.Fixit's Avatar
Oh common Scott, no need to drag reality back into a theoretical disscussion of how to quantify drivetrain losses.
  #23 (permalink)
Old 06-24-2003, 01:41 PM
Sorry. I'll try to stay with the theme.
  #24 (permalink)
Old 06-24-2003, 02:32 PM
Cobra Make, Engine: 427SC Unique
Talking
"PARASITIC LOSS"
When a rice burner follows too close and you blow his doors off and leave him in a cloud of tire smoke only to see you disappear in the distance.
OH I'm sorry that's losing a parasite.
My mistake
  #25 (permalink)
Old 06-24-2003, 02:59 PM
bmalone's Avatar
IRS vs. solid rear should make some difference (higher #'s with solid). Fixit, that sound right?
Bill Malone
Gashole
CSX4786
  #26 (permalink)
Old 06-24-2003, 03:55 PM
Mr.Fixit's Avatar
I would have to imagine that it costs a little bit of power to turn the extra U-joints in the axles. But the handling gains far outweigh that, unless drag racing.
  #27 (permalink)
Old 06-24-2003, 06:28 PM
George Snyder's Avatar
I found this to be interesting reading and does make sense.
DYNO THOUGHTS AND HP LOSSES
After reading various articles in numerous publications on dynos and horsepower, I feel I should put forth a few observations:
Chassis dynos are great tuning aids but they only give a approximation of power output as some of the important variables are not accurately controlled. Certain magazines seem to think that results obtained from chassis dynos are the gospel. They are not. In one recent independent test, hp figures varied by 11% simply by doing the runs in different gears and in another test, results varied by almost 4 % by doing the runs with a different wheel/tire combination. Tire alignment has been shown to affect results up to 3% as well. Note that Engine hp DID NOT change here yet the dyno recorded an increase in hp at the wheels. One can only conclude that inaccurate moments of inertia and correction factors are being used.
On intercooled, turbo cars, there is usually insufficient airflow to ensure accurate results due to charge temperature variation which can be substantial. Even coolant temperatures may not stay down during the run which can affect power outputs considerably. The rate of acceleration is also important on turbo cars to be sure that the boost is not lagging the engine rpm. With RPM climbing too quickly, the boost has not reached a peak value so the hp figure is again inaccurate. Turbo cars should therefore be tested in top gear.
Without proper temperature stability and accurate moments of inertia on the rotating components, there CANNOT be accurate results as the scientific method is no longer being applied.
When all things are kept the same between runs and you get a tangible gain, it is a gain at least. How much, is open for discussion. It is important to note that as the oil temperatures in the engine, transmission and differential increase, friction usually decreases. This manifests itself as an increase in power at the rollers on each subsequent test. This factor should be accounted for when doing back to back runs. It may look like you are gaining some power on each run by making other changes when in fact this is due to reduced oil viscosity. When using a chassis dyno, always use the same gear and tires and wheels and start the runs from the same speed or RPM. Re-baseline periodically to see what temperature increases have done to power output.
Chassis dynos are quick and easy to hook up but have many of the above failings. They do not possess the accuracy of a properly calibrated engine dyno which has a more carefully controlled environment and condition set. Obviously, most non-professionals don't want to be yanking engines to use an engine dyno so chassis dynos do have their place.
Flywheel vs. Wheel HP
As most people know, there are power losses through the drive train so wheel hp is always lower than flywheel hp. Front wheel drive cars with transverse engines tend to be more efficient than most rear drive configurations due to the layout of components. However most publications overestimate these losses considerably.
Most rear drive cars have a 1 to 1, 4th gear which means that the power path goes directly through the main shaft of the transmission. The only losses here are bearing drag which is less than 0.5% and the viscous drag of the gears running through the oil which is about 1% with hot oil. Indeed, published data indicates a transmission efficiency of 98 to 98.5% for conventional transmissions in 4th gear.
Losses within the drive shaft account for about 0.5% if they are properly aligned, balanced and with fresh U-joints.
Differential losses in the commonly used Hypoid type gear set is in the order of 6 to 10%.
The worst scenario case for a rear drive setup is on the order of 12.5% in 4th gear, not the 20 -25% often published. If 25% was being lost in the drive train, the oil would boil in the differential housing in short order and aluminum transmission cases would fatigue and break from the temperatures generated. On a 200 hp engine, something on the order of 37,000 watts would have to be dissipated out of the transmission and differential housings. Obviously, this is not the case.
Transverse, front drive transaxles usually have no direct lockup gears and no 1 to 1 ratio, however, since the torque path is never turned 90 degrees as in the rear drive setup and efficient helical gears are usually employed for the final drive set, losses are more on the order of 6 to 9 percent in the upper ratios.
Tire pressure and wheel alignment can have very significant effects on losses at the rollers. Tire pressures should be set the same between each test. Tire rolling resistance varies inversely with speed, another factor not taken into account by most chassis dynos when applying phantom flywheel hp formulas.
Comparing the Numbers
Many novices are quick to compare hp numbers between chassis and engine dynos and come up with all sorts of wild conclusions about drive train losses. These comparisons are essentially meaningless. Inertial dynos are based on the sound scientific principle of accelerating a certain mass with a known moment of inertia over a given time. The rate of acceleration of that mass and moment is a result of the force applied (torque). If the RPM is known, HP can be calculated. On an inertial chassis dyno, it is virtually impossible to calculate the moment of inertia of every tire, wheel, gear, joint , axle and shaft in the power train between the crankshaft and roller, therefore its results cannot offer an accurate HP figure. Inertial engine dynos offer a very accurate figure if properly calibrated as only the flywheel's moment of inertia needs to be calculated and added to that of the billet. Water brake or eddy current dynos generally measure force (torque) directly through a ram or strain gauge so moments of inertia are not important on these in fully loaded tests.
Concluding that there was a 25% drive train loss by comparing HP achieved on an inertial chassis dyno and that obtained on an engine dyno is fundamentally flawed in that the chassis dyno numbers are highly suspect in the first place.
For you doubters out there: http://www.pumaracing.co.uk/power
Bud
  #28 (permalink)
Old 06-24-2003, 06:43 PM
Cobra Make, Engine: FFR 2836K
I hear that some 550 hp big blocks were throwin out 350 hp numbers at the fling
Your truly Menace FFR2836K
  #29 (permalink)
Old 06-24-2003, 07:22 PM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Just putting the motor in, and still playing with tuning, the carb was running rich...I pulled 428 horse and 560 torque on the dyno at the fling
Jack
XSSIVE .....
  #30 (permalink)
Old 06-24-2003, 07:41 PM
Tom-In-Ohio's Avatar
Default To add to George's comments...
Comparing engine dyno with chassis dyno results .....
Most engine dyno shops use large diameter, long tube racing headers in their set-up. The sidepipes/mufflers do not enter the picture. So, the hp loss due to exhaust restriction should be minimal on the engine dyno.
Things get very interesting once the engine is installed in your Cobra. If you use stock headers and sidepipes (with mufflers), then you will undoubtedly see significant hp loss due to increased exhaust restriction. Probably on the order of 25 to 50-hp. This loss will be reflected on the chassis dyno. Bottom line is, you must consider exhaust system hp losses ON TOP OF powertrain losses. That is, when trying to compare engine dyno hp numbers with chassis dyno results.
Also note that the air cleaner, alternator, and other accessories will contribute to some hp loss, as well.
It's not just the powertrain that robs your engine of precious hp.
Tom
Enjoy yourself, it's later than you think. Enjoy yourself, while you're still in the pink. The years go by quicker than a wink. Enjoy yourself, enjoy yourself, it's later than you think !!!
  #31 (permalink)
Old 06-25-2003, 04:37 AM
Cobra Make, Engine: Classic Roadsters, 393 stroker, Tremec 3550, about 425 hp, MDA GT40 289
Seems there are several factors that could effect hp significantly. I have 1 3/4" headers with DV's side pipe mods. I'm running an Edelbrock Pro Flo air cleaner (which by the way we took off on run #2 and #3 and it actually made 1-3 hp less without the aircleaner. Good ad for Edelbrock, no flow restrictions there.) While standing next to the dyno, I saw three cars remove there air cleaners and gain 20-30 hp. Also, I have a 3.55 axle ratio. Now, my understanding on how the chasis dyno works is based on the amount of time it takes to get the 8000 lb. drums spinning to the cars max rpm. Let's say that with 3.55's @6000 rpm I'm turning 120 mph. I'll garantee you it will take less time for my motor to get to 6000 rpm if I have 4.11 gears and only have to reach 100 mph. Then maybe the results would have shown 370 or 380 rwhp. It's all apples to oranges anyway. I really just wanted to know what my air/fuel ratio was so I could finish tuning the carb. It was just a bonus to find out the hp and torque numbers. I'll leave it at this. "I AM VERY HAPPY WITH THE PERFORMANCE OF MY COBRA!"
Thanks for the input guys.
Jim Downard
Man, it would've been helpful to know that cop was behind me a minute ago!
Rate This Thread:
