Old 10-15-2003, 06:00 AM
boxhead's Avatar
Default Found an engine bigger than Craigs
I found this yesterday whil checkin out another site.
http://users.tpg.com.au/rwwitt/newdr...dragmania.html
It is apparently about 1200hp with a full cooling system and will tour the car shows doing burnout displays.
Cruising in 5th
Old 10-15-2003, 06:53 AM
Now what you gone do that for hey?
Now Craig wont be happy till he beats that number...be like a bear with a sore tooth and Scott will have to start building more pipes and stuff
Sheezzzzz
Old 10-15-2003, 05:18 PM
750hp's Avatar
Box - Ben's new ute is hopefully going to be at www.powercruise.net Should be a bit of fun to watch!!!
Les - you haven't seen pipes until you've seen Mike Moran's QUAD turbo big block Chev.... http://www.hoon.tk/tech_tips/qtv81.html
Probably the most technically advanced Big Block Chev ever built...
Craig
Old 10-15-2003, 07:24 PM
justbetter's Avatar
Cobra Make, Engine: Superformance AUS002, Chev 5.7 with hairdryer
Talking Its not that hard
SEE CRAIG ITS NOT THAT HARD TO SAY
A Big quote from you goes a long way
Come on, Come over to the dark side.....
" YOU KNOW YOU WANT TO "
I'll ask the rest of the crew, im sure the will let you in, just tap you heals togeather and say it three times out loud...
Chevy
Chevy
CHEVY
Garrett
COBTHS
Superformance SPF AUS002 "Modified"
Old 10-15-2003, 11:24 PM
Cobra Make, Engine: Genuine original Unique MotorCars 427 S/C, with a Genuine original Ford 427 Side-oiler.
Send a message via Yahoo to Cobranut
See if you can find anything bigger than this.
http://www.bath.ac.uk/~ccsshb/12cyl/
Old 10-16-2003, 03:58 AM
750hp's Avatar
5,600,00 lb/ft torque Yeeeehaaaaa!!!!!!! Doing burnouts at max rpm of 102 just wouldn't sound the same though..... Gotta love all those head studs !
Garrett - as soon as silver-plated, nitrogen-filled, aluminium tube O-rings that seal Pro-Stock sourced DRCE cylinder heads that are CNC-prepared by none other than Warren Johnson become standard issue on big block chevs, I'll buy one. Until then, they're still just truck engines No, a friend of ine has a 13:1 comp 509 cube BBC in a 4400lb 65 SS Impala. It runs high 10s in street trim with no nitrous, so they most be decent engines...
If I was to build myself a Chev motor, it would be something like this one that's going into an Ultima GTR :
Craig
Old 10-16-2003, 04:35 AM
justbetter's Avatar
Wink Fair
mate you know some people, any chance i can get me one o dem in the front of me SF.
Gaaaauuuud i'd love it
That thing gota go
Thanks for the photo keeps me pushing Aussie Mike to get his wheels turning.
So we might one day work on somthing that hopfully will stop.
Garrett
Garrett
COBTHS
