Old 12-31-2003, 04:24 PM
OZVENOM's Avatar
Cobra Make, Engine: Now built a race cobra.
Talking supra 6 speed.
Well its done finally got the six speed fitted for the 2nd time the first box i got was stuffed noisey and jumped out of 4 th .
then went and bought a nother one with low ks and never opened fitted it and its a sweet as a nut.
nice ratios . now i hope the clutch is up to the task only time will tell.
Hey Craig long time no speak we are going down the coast on sat nite for a cruze coming????
Regards OZ
Old 12-31-2003, 07:03 PM
Aussie Mike's Avatar
Hi Scott,
Good work on getting the Supra box in. Hopefully this one will be up to the challenge that little monster motor deals out.
Is the Supra box a double overdrive unit like the T56?
I thought you had a fancy Japanese twin plate clutch?
Mike Murphy
Melbourne Australia
Old 12-31-2003, 07:46 PM
OZVENOM's Avatar
Talking $$$$
Hi mike no its only 6th that is a od . great fun to drive keep rowing thru the gears.
the twin plate clutch is $1800 and i just didnt have the $ at the moment so i had the single plate moded its now got 2800 lbs of clamp and a 5 button solid centre plate.
Now we see if it will hold 1500lbs of torque.
oz
Old 01-01-2004, 04:24 AM
750hp's Avatar
Scott - I've been avoiding you, hoping that you'd forget about that great cobra book I borrowed a couple of weeks ago....
I'm supposed to be meeting some people in Maleny at lunchtime on Saturday. If I'm back early enough, I'll give you a call. What time are you leaving?
Bummer about the first Supra box... Was there much chassis work to get the 6 speed in the Harrison? 1500lb torque? Have you gone and fitted a Top Alcohol engine into the Cobra??? (Just kidding - I know you meant tractive effort at the tyres!)
Old 01-04-2004, 08:58 PM
PCC's Avatar
PCC PCC is offline
So when's this beast of a thing going to run past those permanent road treads made by that fella in that blue Cobra with the inverted boogie board on its front?
If you do, call in for a drink (cursery call 10 minutes before arriving would be good).
PCC (Peter Craig)
Keep the sun shining
