Old 02-26-2004, 10:40 PM
BJ's Snake's Avatar
Default water pump question
Hi guys
Has anyone changed their water pump from a reverse rotation to a standard rotation,if so do you know make and part number to suit 87 5 litre windsor mustang.Iam not having much luck with advice from so called experts around this town.
BJ
Old 02-26-2004, 11:56 PM
Hiya BJ, I had the same problem. I have a 302W 1987 block which had the reverse rotation (serpentine belt) pump. Blu$$y heavy cast iron pump which had a puny little pressed steel impellor.
I changed the timing chain cover to a SVO M-6059-D351 which has provision for a mechanical fuel pump (I blanked that off) and a front dip stick hole. ( can blank that off too if you prefer the side dip stick.)
On front of that I used the SVO M-8501-F351 standard rotation alum. pump which has the CNC machined impellor which does not cavitate as much as the pressed ones. Also uses ball/rollor bearing for the shaft.
This pump is said to provide max flow & pressure with equal distribution to both banks.
Dont be talked into any of the so called race pumps as they flow low volume at street revs.
Hope that helps
Old 02-27-2004, 05:56 AM
Cobra Make, Engine: unique 427 302/300hp t/5
try and get ford motorsport catalog and you will find the part .and if you can find one give me a call on saturday at home 305-665-2796 /305-495-3418
Old 03-01-2004, 03:08 AM
BJ's Snake's Avatar
Thanks Rebel1,
I was hoping that I did not have to change timing cover.They say a Ford Crown Vic [whatever the equivelant is here in OZ] water pump is standard rotation and bolts straight up to 87 Windsor . I will do a bit more research otherwise just get one from the states as this seems to be the easiest way to get any thing that fits first time around. As you can see I am very disallousioned with the help I am getting in this %$#@hole we call the National Capital.Wish I was back in Gods Country with You guys.
Cheers BJ
289 FIA Cobras RULE!
Old 03-01-2004, 04:23 AM
289,302,351w standard rotation pump # is m8501-g351 from ford hope this helps if you need one call you have my # and i will ship it to you . it,s alumnium housing and good for 6000 rpm if you plan on running higher rpm them use #m8501-f351 also aluminium housing
