Old 03-14-2004, 11:15 PM
pneall's Avatar
Default Tyre wear.
Not sure if this has been covered before but what sort of km's do you guys get out of a set of i) front tyres and ii) rear tyres.
The brand of tyre used would be interesting also.
What pressures do you run. I have been told somewhere between 20psi and 25 psi works OK.
Phil
Old 03-14-2004, 11:29 PM
Aussie Mike's Avatar
Garrett should chime in here. I think he's single handedly keeping Bob Jane in business. What's it been, 2 sets of rears in 7,000KM?
I've got a pair of his worn out rears in the back of the shed and there ain't much left on them. All torque and no traction
Mike Murphy
Melbourne Australia
Old 03-15-2004, 05:07 AM
BMK's Avatar
BMK BMK is offline
Just about fu#^@d my tyres in 12,000k's. Must be the rough highways Mrs. REPTYL talks about.
Bernie
Bernie Knight
Old 03-15-2004, 05:23 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Tyre or Tire wear is directly proportional to the type of driving and the road conditions.
If you're gonna play, you're gonna pay.
If you chaps would quit driving up-side-down, may be the tires would last longer. LOL
Typically I got around 10k miles out of a set of rubber. But, that was a good 20 to 30 years ago.
Hope this helps.
Old 03-15-2004, 06:48 AM
BMK's Avatar
BMK BMK is offline
I just cannot work it out?
Is it the driving up side down or the constant 360's that cause wear.
Bernie
Bernie Knight
Old 03-15-2004, 09:53 PM
justbetter's Avatar
Cobra Make, Engine: Superformance AUS002, Chev 5.7 with hairdryer
Default Balding
Yeah thanks there Mike,
Not happy with my tire wear, but i've worked out that if i leave the gal in the shed the tires last longer.
Mind you shes in the shed still at CTC with that special development issiue being attended to, although i think this may increase the excessive tire use
Mike if i take even more of the preload off the rear will this help ?
Thanks in advance.
Might look at those pilot tyres
Garrett
COBTHS
Superformance SPF AUS002 "Modified"
Old 03-16-2004, 02:07 PM
Cobra Make, Engine: 1st Harrison with Gen 3 , 6 speed ,Godzilla diff & brakes
I dont know what you guys do with your cars but that tyre wear seems a bit excessive . Just remember though the bigger the tyre width the softer the rubber needs to be to hold you to the black stuff . I have 235/35/18 on my clubby and i just changed them after 18,000 and i do a bit of excessive driving around corners and also this car weighs in at 1700 kg so i would have thought when my Cobra is on the road i should get more then 20,000 as it is so light .
Old 03-16-2004, 03:59 PM
Shelby400's Avatar
Cobra Make, Engine: Homebush. Lexus quad cam V8, R154 Supra box. Oh what a feeling.
The lighter the car, the heavier the right foot.
!!Its good to be stroked but i'd rather be blown!!
Proud member of the Bclub Central Coast chapter
Old 03-16-2004, 07:59 PM
BMK's Avatar
BMK BMK is offline
What do we do????
Numerous 360's (donuts)
Roll backs
360's out of corners.
Drifts
Sideways drifts into the parking line
Burnouts
And that's all at McDonald's through the Drive - Thru.
Bernie
Bernie Knight
Old 03-17-2004, 07:17 PM
justbetter's Avatar
Default Can I have a go
Can I Have a go Bernie
Can I , Can I
Garrett
COBTHS
Old 03-17-2004, 07:31 PM
Default Re: Can I have a go
Can I , Can I
Nope, you've already done your bit for the greenhouse effect.
Mike Murphy
Melbourne Australia
Old 03-19-2004, 02:55 PM
justbetter's Avatar
Default mmmmm
BUGGER
Garrett
COBTHS
Old 03-19-2004, 03:10 PM
boxhead's Avatar
I have been for a quick lap around the block with Garrett & I can fully understand why his tyres last 7000 kl, I allmost would have thought that was a good number of k's on his tyres.
Cruising in 5th
Old 03-19-2004, 10:34 PM
BMK's Avatar
BMK BMK is offline
Exclamation
Your welcome to go for a spin through.
Anywhere but Mt. Gambier
Niddrie would be your closest!!!!
Bernie
Bernie Knight
Old 03-20-2004, 03:02 AM
justbetter's Avatar
Talking
On My way will post the pic's
Great to have your permission
Thanks Bern
Garrett
COBTHS
Old 03-21-2004, 01:42 AM
BMK's Avatar
BMK BMK is offline
Just grab me a Big Mac
Bernie
Bernie Knight
