Like Tree1Likes
Old 04-17-2004, 03:13 AM
BJ's Snake's Avatar
Default Door latches
Hey Guys
Any ideas on what may be the best sort of door latch system to use.Meaning ease of install and bulletproof once in.I have been told xf Falcon ones are ok but am still interested in any feedback anyone may have due to their own experiences.
Cheers BJ
Old 04-17-2004, 04:17 AM
WILDAC's Avatar
Cobra Make, Engine: RCM under construction since 3.4.04.Powered by Chevy Gen3,Auto and shortened series 3 Jag suspesion.
Hi Bj,
Just got done fitting Mazda 323/Ford Laser locks to mine, the reason we go with these is there about the smallest around and very cheap and easy to find, mine are from a 91 model.
I'm also thinking about fitting the rear hatch lock to the boot as its cable controlled!
Theres pics in my gallery of the assembly
Hope you find what your looking for!
Cheers Robo!
Old 04-17-2004, 06:44 AM
boxhead's Avatar
My kit uses the XF falcon lock assys
Cruising in 5th
Old 04-19-2004, 03:42 AM
BJ's Snake's Avatar
Hey guys
92 views, 2 replies,whats goin' on.Appeciate the replies,got any photos Boxhead of install and intrusion bar set up.
Thanks BJ
289 FIA Cobras RULE!
Old 04-19-2004, 05:06 AM
Cobra Make, Engine: G-Force 5.0lt HO EFI T5 Jag SeriesIII Suspension
My kit used a door lock and striker from a Morris Marina, probably the only thing you would want to use from this car.
The only reason I went with this option was the hole was already cut in the door to accept this type of door lock, but they were very hard to find new.
The opening mechanism was from an early corolla, very easy install I think I had the whole set up fitted in a couple of hours with no effort. Other kits I have seen have gone with the falcon door locks.
Stuart
Old 04-19-2004, 03:16 PM
REPTYL's Avatar
XF strikers on mine with EF Fairmont handles.
(Stu) I've used a Marina wiper box.
Old 04-19-2004, 03:28 PM
Marina latches here, with handles from Don Pilling (Snake Bite)
The handles are a simple chrome lever, going thru a polished alloy threaded bush/bezel with a lever behind.
Marina wiper box also.
Old 04-19-2004, 04:42 PM
REPTYL's Avatar
Les,
Only a little Marina wiper box.
I can understand a Vic Cobra using one 'cause 3mm is torrential for us.
I thought you would need a 6 speed 4 arm 50 kw monster to get through one of your sun showers
Old 04-19-2004, 05:41 PM
Bryan Wilson's Avatar
Talking Door latches
My latches are ex MG original OEM
Bryan
VK3KDN
Old 04-19-2004, 06:10 PM
Hehehehe Jas,
Actually, I was gonna use a infinitely speed adjustable one but decided against it.......The first wife would have objected to cranking the handle.
Now dont you start on me.... I've been tryin very hard to be nice to you fellas.
Old 04-19-2004, 10:25 PM
Adrian S's Avatar
Cobra Make, Engine: G-Force, 351W, GT40 Lightning Intake, Toploader, Jag running gear, 3.07 diff, Autronic ECU
I had Morris Marina locks with the lever but the lever was digging in the back of my arm. So I changed them to XF door latches with Austin Maxi (now there's a car !) door handles.
Old 04-19-2004, 11:28 PM
PCC's Avatar
PCC PCC is offline
BJ,
Mine are out of a Jag (electronic - no handles).
Driver's sid flip up operates the boot.
Would post a pic, but the car's away at the Paint Shop receiving some make up work
PCC (Peter Craig)
Keep the sun shining
Old 04-20-2004, 03:30 AM
Cobra Make, Engine: Classic Glass, XR8 5.0L EFI, T5, XJS LSD Rear end.
Hello All,
I don't mean to "hijack" this thread. But I did see the name Don Pilling (Snakebite) mentioned.
Appreciate if someone can give me his telephone number. I am in need of some "shiny bits" for our car.
Over riders, bumpers etc.
Kind Regards
Lyn
Old 04-20-2004, 04:38 AM
Cobra Make, Engine: DRB,Ford Tickford 302 220kw with BTR 4 speed auto, 3.9:1 LSD
Hi Lyn,
Don & Vicki Pilling, Snake Bite 07 5529 0877
My DRB uses Ford XD rear locks
LHS is part no XDF 21812B
RHS is part no XDF 21813B
LHS & RHS Striker is part no XDF 2008A
The interior door handle is from a Ford Laser
I got all the bits from the wreckers and found the locks pretty easy to fit.
Cameron
Old 04-20-2004, 04:59 AM
BJ's Snake's Avatar
Now I got something to think about,Thanks heaps for your input one and all
Cheers BJ
Old 04-20-2004, 09:41 AM
Cobra Make, Engine: B&B 408W, TKO 600, 9" 4-link Truetrac, 13" X 1 3/8" curved vane frt disks
I'm still hoping someone will post pics of an XF assembly. In the meantime, does anyone know where JBL gets their latch assembly?
Old 10-29-2017, 02:21 AM
Default Fitting xf falcon door locks
DaveR
I am currently building a classic glass cobra and have the xf falcon door lock and latches. I am looking for any advise on the fitment to the door intrusion bar etc.
Did you ever get any photos or do you have any of your construction
Mal
Old 10-29-2017, 11:49 PM
Donunder's Avatar
Is this a record for the time lapsed between posts? Thirteen and a half years?
guye likes this.
Don.
Old 10-30-2017, 04:46 AM
stephen low's Avatar
Default XF door locks
Here's a couple of XE falcon lock shots in a G-Force door.
Think these are the same as the XF.
https://images2.imgbox.com/25/ce/4VmfQpvB_o.jpg
slowy
Old 11-03-2017, 04:59 AM
I've got XD falcon latches modified to look and work like MG latches.. Sorry I can't find pics .. I'll keep looking and post later.
