05-10-2004, 10:30 PM
Avo Coil over Shocks
Hi Guys & Gals
Looking for a pair of AVO adjustable coil over shocks (600 lbs +) to fit a DRB Jag rear end.
Second hand's fine as long as in good condition (Spending too much on the car - what's new)
Any help?
Currently have Hot Shock Billet adjustable type with 450 lb springs (Too soft / too low at the back end
Thanks in anticipation.
PCC (Peter Craig)
Keep the sun shining
05-10-2004, 10:42 PM
VIC
Hi Peter,
The price on AVOs new isn't to bad. You can get them through Austrack Motosport in Sydney. Give them a call before you go to far down the second hand path as you might not save yourself to much money.
Mike Murphy
Melbourne Australia
05-10-2004, 11:18 PM
Thanks Mike,
I memory serves me right (which it probably doesn't) the cost new is $800 to $850.
For a good shock / spring setup it doesn't seem much, but recently I've been spending too much on the snake in the shed  and am simply trying to justify to myself that any more dosh spent is "well spent" (patience is not my best virtue).
You DRB Jag specialists - what length of shock should I be looking for to fit comfortably?
PCC (Peter Craig)
05-11-2004, 02:09 AM
vic
Cobra Make, Engine: RCM under construction since 3.4.04.Powered by Chevy Gen3,Auto and shortened series 3 Jag suspesion.
Hi PCC
Here's a great link for you has all the info you'll ever need for Jag suspensions and much more http://www.erareplicas.com/freeman/427.pdf
Hope you find what your looking for
Cheers Robo
07-06-2004, 06:28 PM
NT
Hello again everyone, I am wanting to order my springs and shockies today but I left my paper work at home, does anyone know the part numbers for the springs and shocks as needed for the Classic Revival kit?
It is no biggy as I have all the info at home but am keen as mustard to order these bits.
Cruising in 5th
07-06-2004, 07:10 PM
nc
Cobra Make, Engine: SPF with 514 and tko
AVO
PCC,
I have a set of AVOs with springs for sale that came off my Superformance MKIII. The AVOs have a little over 7000 miles on them and are in very good condition. The reason I changed was I went to the Bilsteins that come on the new Superformance cars. How about $300.00 plus freight
07-06-2004, 07:42 PM
You've got mail!
PCC (Peter Craig)
07-06-2004, 08:10 PM
WI
Sorry for the minor hi-jack PCC,
Millennium... What is you assessment of the difference between the AVO and the Bilsteins on the MkIII... The AVO are adjsutable and the Bilsteins fixed, yes? Do you miss the adjustment?
Cameron
07-06-2004, 08:33 PM
Cobra Make, Engine: G-Force, 351W, GT40 Lightning Intake, Toploader, Jag running gear, 3.07 diff, Autronic ECU
Anyone else have a set they want to get rid of? Like PCC, I'm spending way too much on the beast but have a wish list a mile long.
When I put the car on some rubber, the height setup was all wrong so I'm either going to get adjustable shocks or re-temper the springs or perhaps both. I'm running Jag front and rear so thats 6 of 'em I need.
Adrian.
07-06-2004, 09:05 PM
nc
AVO
Cameron,
In my humble opinion the spring rate on the older SPF cars with the AVO shocks is too stiff. They work fine on smooth roads but make the rear end of the car pogo over a dip at speed. The new SPF cars have a lower spring rate along with the Bilstein shocks. So my car handles much better over dips with the Bilstein shocks and new springs. And trust me the roads around here have a lot of dips.
07-06-2004, 09:23 PM
WI
Thanks Millennium200,
There are a fair number of dips around here too! How is the ride height, and have you had them on a track?
Cameron
07-06-2004, 09:42 PM
nc
Cameron,
The ride height is adjustable, so my car is set at the recomended 27 inches all the way around at the fender flair. No tracks close by and besides I am to old for that. My wife and I have driven across the country once in the SPF and are planning another 4000 + mile trip shortly. Long trips are more fun than race tracks for me.
07-06-2004, 10:00 PM
WI
Never too old, just less inclined..
Thanks for the input
Cameron
07-08-2004, 03:07 PM
Millenium2000,
Did you get my E-Mail?
Sent to your Cobra mail.
PCC (Peter Craig)
07-08-2004, 07:46 PM
nc
AVO
PCC,
I received one email on 7-6-04 about springrate, adjustability, shipping, etc. which I replied on the same evening I received it. I sent the email to you personally instead of CC.
07-08-2004, 10:18 PM
Send it to:
cmsmail@bigpond.net.au
Too many E-Mail addresses - sorry
PCC (Peter Craig)
