Old 06-07-2004, 04:54 AM
Cobra Make, Engine: Locally build Chassis and Body Mould. 351W ( 520HP) TopLoader,9" LSD with 3.5 Gears
Question Mounting locations for Windscreen etc
Does anyone have dimensions for the mounting locations for windscreen , rollbar , front & rear bumpers , fuel filler etc
Car is RHD (NZ) and can't find this info anywhere
Paul
Old 06-07-2004, 07:17 AM
Cobra Make, Engine: Self Built, 427 USRRC, 427FE, Toploader
Default dimensions
haakerp,
For instance the body cuts for a AC windscreen are usually are 1296mm apart to the inside faces of the side attachment bars, and are 62mm x 12mm openings. Measured across the surface of the aluminum cowl the are 1320mm apart to the inside faces.
This is for an AC, but you should use a windscreen and measure it to get YOUR REQUIRED DIMENSION, in that way since the Originals vary a few mm's from the current market. A NOTE; between the three suppliers world wide they vary between each other a few mm's.
Then the angle, that would be a function of the compounding cowl radii and the location of the side bar supports on the cowl support, who knows, your fabricator would.
Dangerous game without the parts in hand.
grumpy
Old 06-07-2004, 04:30 PM
PCC's Avatar
PCC PCC is offline
Paul,
I have some info on a DRB, but may not be relevant to your particular model.
What model have you got?
PCC (Peter Craig)
Keep the sun shining
Old 06-10-2004, 03:32 AM
What Model ... didn't realise there were "models" ?
It's a 427 SC replica ... what else can I say ?
90" wheel base and approx 64" track ( measured at front wheels)
Paul
Old 06-10-2004, 05:26 AM
PCC's Avatar
PCC PCC is offline
What I was getting at is if your car was built by one of the kit manufacturers then it is likely that they have spacing c/c etc required for what you want.
If not, then you'll just have to make it fit.
PCC (Peter Craig)
