questions
- » Blogs
- » Image Gallery
million posts!
| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
07-26-2004, 07:45 PM
vic
Cobra Make, Engine: 302 windsor, trickflow heads, gt 40 intake, 65 mm throttle body, autronic computer, custom headers, glimer drive , toploader
second problem
Noise there is something happening to me am i just old???? the gilmer drive on the front sometimes its just abit much any way of knocking the edge off it. rumours have said to drill something some where good idea HUH??? love to know where though
king jason the 2nd
Advertising
07-26-2004, 08:12 PM
QLD
Sounds like alot of jibberish to me!
What are you trying to say  ?
PCC (Peter Craig)
Keep the sun shining
07-26-2004, 08:38 PM
ca
I read it Four times and don't get it?
I thought it was a down under thing
Mike
07-26-2004, 08:59 PM
Qld
if that's your second problem....hate to see the first
07-26-2004, 09:38 PM
CA
I think the first is grammer.
07-26-2004, 09:55 PM
VIC
Give him a break, it's tough at the top.
Paidup, Leeroy
07-26-2004, 10:13 PM
Cobra Make, Engine: RCM, 4 wheels, two doors
Well, at least he's STOPPED SHOUTING ALL THE TIME!
07-26-2004, 10:19 PM
QLD
Not knowing Jason's heritage I thought maybe he writes in greek or italian and then uses one of them language conversion software packages
Obviously stressed out with all those noises going on
PCC (Peter Craig)
07-26-2004, 10:21 PM
TX
Have another beer Mate, it'll come to you!
Flip
07-26-2004, 10:47 PM
QLD
Cobra Make, Engine: drb probably a LS1
Jason,
Don't worry about all these low lifes that are like vultures just waiting for some poor innocent guy to make a mistake.
Now I think what your saying is the gilmer drive belt is making alot of noise and it's getting on your nerves. If so maybe it could be either to tight, to lose or just not worn in - a belt that is new compared with a worn belt can vary quite alot in thickness and in width.
Darryl
P.S One more hint - try not to drink 2 bottles of scotch before posting next time!!
07-27-2004, 12:23 AM
Zzz
You're OK its everyone else that is crazy
Jason
I had considered gear drive as I just love that sound. Quite apart from the obvious advantages over a chain.
Hey, tell me how you get the belt to make that noise. My belt is dead quite.
Will watch with interest to see what is suggested to quieten the gilmer belt down and then just do the opposite - I guess.
Love that sound.
Bernie
Bernie Knight
07-27-2004, 12:28 AM
QLD
ermmmmm
ahmmmmm
Nuh!...not sayin anything
07-27-2004, 12:46 AM
Zzz
It's tough at the top
The door bells ringing and there is a guy in a white coat standing there.
Should I answer it.
Sorry Jason - aaaah KING JASON II - You will have to condition yourself to the noise. The roar of your club members as you enter the room will be far louder.
Bernie
Bernie Knight
07-27-2004, 04:04 AM
VIC
Cobra Make, Engine: 1991 RMC 1966 427SC replica, 302 Cleveland, Edelbrock manifold with 600 Holley double pumper.
Jason,
I may have a solution for you. The noise is possibly a couple of things.
1. Too tight, (gilmer drives dont need a lot of tension). If too to tight the belt may not be meshing correctly on the drive.
2. The main noise is from air being squeezed out of the toothed area. I have heard a solution to quieten these down is to drill holes in the milled (lower) section of each of the drive wheels. Check the internet hot rod chat sites or search "gilmer drives". (you will need to drill a couple of holes in each section check out more info from other sites)
3. If its new it may be the drive gears have some sharp edges catching on the belt. May need to smooth off rough edges.
Hope this helps.
TC
07-27-2004, 07:11 PM
vic
TYPICAL
Thankyou all for your wonderful advise as per usual 13 responses and all bar 1 (thank you tony ) was next to useless. Random abuse will be rained down on you in the future
king jason the 2nd
07-27-2004, 08:00 PM
CA
Cobra Make, Engine: Johnex EQ
Tony gave you the scoop. Check the ten. first. Then drill the holes, to let the air out. Also make sure you have the correct belt..
Ed
Johnex EQ 514
07-27-2004, 09:18 PM
Zzz
Do we drill holes in every indent between each tooth.
How many each?
Does anyone know how to make them sing - get that whistle sound for those of use who want the noise?
I love ther sound of gear drive and belts that sing/hum
Bernie
Bernie Knight
07-28-2004, 04:15 AM
Member of the north
Cobra Make, Engine: A Cobra
I had to turn the entire post 'up-side-down' to read it correctly.
So, if you play it backwards; does it say Paul is dead?
LOL
07-28-2004, 06:48 AM
AZ.
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
07-28-2004, 04:00 PM
VIC
Bernie,
From what I can find out it is holes drilled in every milled section. Will try and find out more and post reply. Not sure why yours does not make any noise unless it has holes drilled. Mine is well worn and can be heard in the cabin easily. Other possibility is worn belt (ie square sections have too much slack and air not getting trapped.) or incorrent belt as "ebustin" suggested?
Anyway will try and find out more.
PS. They must have run out of moonshine over there into kerosene now??????
TC
