08-13-2004, 06:33 AM
VIC
Roll bar set up
Hi All,
I've been messing about with my roll bar setup lately. It a job I've been meaning to finish for a while and since the painter wants to start soon I thought I'd better get it done and get all the holes cut.
It made from 60mm OD aluminium tube with a heavy 5mm wall. The mounts in the chassis were made for 2" OD tube so I had to machine up some stepped down sections for the ends to make it fit nicely.
The 60mm OD tube looks a bit chunkier than the normal 1.5' or 2" bar but it's quite subtle and looks good in my opinion.
I also modified the mounting bracket to make it stronger since I was worried that it might deflect or collapse in the case of a rollover. I added a shear plate accross the back of it to triangulate the whole thing.
What I've got to do now is make up the mount on the boot floor for the 3rd leg. I've got to also add a coresponding bracket off the chassis underneath to sandwich it to the fiberglass.
Once the last bracket is done I'll get the back brace Tig welded on. The step down sections on the ends will be plug welded and I'll also drill and tap the sleeve on the brace and retain it with some countersunk stainless cap screws.
The aluminium tube polishes up nicely and should come up like chrome with a bit of work.
Here's a few pics.
Roll bar in pieces
Roll bar
Braced mounting
Holes cut
Mike Murphy
Melbourne Australia
08-13-2004, 03:27 PM
Vic
Cobra Make, Engine: Superformance AUS002, Chev 5.7 with hairdryer
Lucky lady
And where is the wifes one ?
Garrett
COBTHS
Superformance SPF AUS002 "Modified"
08-13-2004, 08:59 PM
Your right Mike it does look good. I really like the idea of the braced bracket, I think Ill do the same. Great stuff.
Regards.
Mando
08-16-2004, 01:52 AM
Zzz
Will you be placing a rubber or aluminiun ring around the bar?
The back bar looks as if it is nearly a perfect circle through the body?
Bernie
Bernie Knight
08-16-2004, 02:54 AM
VIC
The hole for the rear brace is oval. I was just lucky enough to get the angle on the hole saw spot on when I drilled it.
I'm machining up some aluminum trim rings but there will be a thin neoprene gasket under each of them to keep the water out of the boot. You can buy 1.5mm neoprene sheet from Clarke rubber and I'll make some large wad punches from exhaust tube to cut it out neatly.
Unfortunately no roll bar for the wife yet, I'm still contemplating that. I've got another hoop there but I like the asymetrical look of the single drivers hoop. I may make up a full width bar that I can swap back and forth. I'll machine up aluminium caps for the unused holes in the bodywork.
Mike Murphy
Melbourne Australia
08-16-2004, 03:51 AM
Ermm Mike
Ahmm ...
Do you often find yaself wanting a bar bigger than the average??
08-16-2004, 04:26 AM
Vic
Cobra Make, Engine: RMC, 302Windsor HO Stock
Hey Mike
I'd probably stay with a single hoop
It's highly unlikely you would be going fast enough, or doing anything daring enough, for a roll-over with the wife in the car!!!!!
Lest ye suffer the wrath of the ALMIGHTY backhander
Just sharing experience!!
Batman
Please have some sympathy for the HP challenged
08-16-2004, 11:28 PM
My preference Mike for what its worth is two hoops along with two raydot mirrors - it just seems to balance the car out.
Not that the passenger mirror is any use as you can't see anything for the windscreen.
I know its not original, but it does seem to give the car some balance and it looks awesome from the back (a Cobra's best angle I think).
PCC (Peter Craig)
Keep the sun shining
08-17-2004, 12:01 AM
Zzz
I am after three of the aluminium rings. Two circular and one oval - template provided.. Are you able to do these? Will ring you re cost etc.
bernie
Bernie Knight
08-17-2004, 12:09 AM
I'm going to install 2 hoops but with no third arm. I'll have an OD somewhere b/w 60-70mm and the hoops will be reclined on a small angle. Having 2 hoops with the third arms, for my tastes, puts too much shiny stuff on the back of a cobra which detracts you from those beautiful lines from behind. It's only fair that Mrs NASSTY enjoys as much protection as I do. But lets all hope that no one has the opportunity to test their rollbars out b/c a cobra has bugger all protection else where.
08-17-2004, 12:12 AM
VIC
Can do Bernie. I can do them in polished aluminium. Stainless is a pain to machine.
Pete, I like those Raydot mirrors too. I might have to look at a second roll bar since I was looking at some fiberglass race seats today. The roll bars will take the attention away from the head rests.
Mike Murphy
Melbourne Australia
08-17-2004, 12:41 AM
Zzz
Mike,
Thanks, we can check the measurements out when I call over.
Polished aluminium would be excellent.
Should be around two or three weeks before I get over, all going ok.
Bernie
Bernie Knight
