Old 08-27-2004, 04:46 PM
Cobra Make, Engine: DRB,Ford Tickford 302 220kw with BTR 4 speed auto, 3.9:1 LSD
Default fuel tank problem
Hi There,
I've emailed Peter at DRB about my problem but thought I'd post it here as I usually get a faster response.
I have an aluminium fuel tank. As per DRB specs I have made an aluminium cover plate and attached a bracket to hold the EB Falcon fuel pump.
I got some steel tubing for the fuel line in and out. I went to my local radiator man to get the tubing welded in and he tells me that steel and aluminium cant be welded together.
Originally, I was going to use aluminium tubing but the wall thickness is much greater. So if I use the same outside diameter aluminium tubiung then the inside diameter is greatly reduced (restricting fuel flow). OK so why not match the inside diameter I hear you say. When the inside diameter is the same, the outside diameter of the aluminium tubing is too large to fit into the fuel pump.
Any ideas?
Cameron
Old 08-27-2004, 09:35 PM
boxhead's Avatar
I too until recently thought that aluminium and steel couldnt be welded together, until I saw it done.
I will ask the tech at work who showed me where he got the welding rods from and I will post the answer for you.
Cruising in 5th
Old 09-05-2004, 05:34 AM
boxhead's Avatar
Hello Cameron, sorry it has taken so long for a reply.
The welding rods that I saw used to weld aluminium to steel are called ultrabond.
There is no website address on the paperwork I have for it but there is a contact number and address.
Contact Ray & Lucie Burge
Po box 53, Montville QLD
4560
Ph/Fax 07 5442 9259 or Mobile 0429060571
It is used in a similar way to soldering and the most important part is that you must clean area useing a stinless steel wire brush
Cruising in 5th
Old 09-05-2004, 10:29 AM
Cobra Make, Engine: Levy Racing built FFR w/351W
Before you try to do the welding/bonding/brazing, have you thought of AN bulkhead fittings with O-ring seals? You can get any size you want, adapters, etc.
Old 09-05-2004, 09:34 PM
PCC's Avatar
PCC PCC is offline
Cameron,
Obvious answer - why don't you run some flexible fuel hose from the cover plate to under the car or wherever and then link back into s/s fuel lines?
Or am I off the beaten track?
PCC (Peter Craig)
Keep the sun shining
Old 09-05-2004, 09:40 PM
PCC's Avatar
PCC PCC is offline
Sorry Cameron,
Misread your query in haste
Pretty sure my inlet and outlet lines are aluminium (no car to check - sorry)
My pump is an NC Fairlane (V8) and it fits okay.
With the EB pump is it off a 6 cylinder?
I was told by Ford that all the V8 pumps are the same and similarly the 6 cylinder one's are different.
On my old pump the plastic take off is 8.5m o/d with an internal dia of 5mm.
Does that help????
PCC (Peter Craig)
