Old 02-09-2005, 02:27 AM
WKB's Avatar
WKB WKB is offline
Cobra Make, Engine: Harrison Cobra, SC540 Roadster
Default 400TT / OZVENOM Suspension Querry
Gentleman
Like your vehicles I have a R32 GTR rear suspension setup. To attach the shock/spring units I fabricated brackets to clamp on to the hub carrier. With the suspension now attached it is 50mm higher than if I had used the cast iron hub carriers. I am using King Spring Pt No KPS 188 250lbs.
Are these the springs or eqivilant the ones you used or if they are not what springs would be the best to use.
Warren
Old 02-14-2005, 04:11 AM
OZVENOM's Avatar
Cobra Make, Engine: Now built a race cobra.
Lightbulb springs
Hi i used some kings springs that are 200 lbs sorry cant remember the part number but 250's should be ok though a little stiff. front i used 450 lbs and the ride is comfortable.
but still stiff enough for track work.
OZ
