Old 02-20-2005, 02:18 AM
Cobra Make, Engine: Classic Revival, LS1, Shift kitted auto, high stall, AU LSD rear.
Has anyone with a Classic Revival kit considered redrilling the fronts to suit the rear or visa versa? I have been pondering the idea and have wondered if anyone had done it yet.
Gav
Old 02-20-2005, 04:28 AM
boxhead's Avatar
I did think about it but there is nowhere to carry a spare anyway so why bother?
Cruising in 5th
Old 02-20-2005, 03:38 PM
Aussie Mike's Avatar
I considered doing a space saving spare wheel for mine. I decided not to bother when I thought what do you then do with a 17x11" flat tyre? do you sit it on your wifes lap while you drive to the tyre shop? I figure a can of fixa flat or a tyre plug
kit and some CO2 cartridges would be a better option. Or even better an RACV membership and a mobile phone.
If you really want a spare just buy a dual bolt patern Weld racing drag lite rim. They are available in 15x6" and all you need to do is carry a set of 1/2" shouldered wheel nut to suit it. They are light weight and fairly compact and would fit in the boot OK. The only problem I see with it is the difference in center bore diameter between the Jag and Ford hubs. You could machine up a spacer ring to slip in for the smaller ford center bore.
Mike Murphy
Melbourne Australia
Old 02-20-2005, 08:30 PM
Just been advised by ozwheel that they will manufacture knock off adaptors. They have been making them for porches for ages. Now available for cobras.
Just tell them what stud pattern and they'll make em.
I've been asked not to advertise the price quoted until they finalise pricing but I believe the price to be quite competitive.
Go get em
Old 02-21-2005, 12:30 AM
Cobra.au's Avatar
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
Here is the OZ wheel dark grey
Craig W
Central Coast NSW
Old 02-21-2005, 12:31 AM
Cobra Make, Engine: 1st Harrison with Gen 3 , 6 speed ,Godzilla diff & brakes
Talking
Gee i think if the guys with Classic revival kits used the Knock off adaptors then put the wheel on they would have no offset left .
Paul
Old 02-21-2005, 02:12 AM
The adaptor only adds 10mm each side. The bolt on wheel centers have an aproximately 15-20mm thick raised section where they bolt to the hub. This is to make clearance between the wheel center and the brake calipers. With the knock off adaptor adding 10mm clearance you don't need this raised section so the back of the wheel center is machined almost flat.
Here's the clear powder coated centers:
Mike Murphy
Melbourne Australia
Old 02-21-2005, 02:17 AM
You'll note that Craig's Classic has more dish on his front wheels than mine. Ian changed the design of the front suspension on Sloths and my car which came out after Craigs. He moved the suspension pivots further out to use a wheel with a smaller scuff radius.
I thnk Craig's is also the last car with floor mounted pedals. I kinda liked the floor mounted pedals.
Mike Murphy
Melbourne Australia
Old 02-21-2005, 02:59 AM
Cobra.au's Avatar
You are right mike mine was the last CR with floor mounted pedals
not sure if that is a good or bad thing?
Craig W
Central Coast NSW
Old 02-21-2005, 03:15 AM
Well...all you CR replica owners need do is convince ozwheels to make a flat spinner just for you fellas.
Us normal folk can still use the heavily dished spinners which hide inside the wheel.
Whichever way....Ozwheel is making the adaptors....so there
Old 02-21-2005, 03:28 AM
Les and Normal
Those two words don't really fit together.
Mike Murphy
Melbourne Australia
Old 02-21-2005, 03:43 AM
Wots wrong wif me heh?
  #33 (permalink)
Old 02-21-2005, 03:52 AM
Mike Murphy
Melbourne Australia
  #34 (permalink)
Old 07-26-2005, 02:46 AM
Hi All
Has anyone polished the centres of the ozwheel halibrand and if so how do they come up . I would want mine polished to within an inch of its life . If they cant be polished i will consider Alsa corps Chrome paint finish .
Regards
Paul
  #35 (permalink)
Old 07-26-2005, 05:47 PM
Leeroy's Avatar
Ledge
someone here might remember seeing in SnakeTales a new wheel manufacturer here in Melb, I cant recall details though. They do a Hailbrand replica which look very nice & in many sizes etc. Not sure price options but would certainly be worth a call to check. Someting like Millana ??? someone here help if they know
Leeroy
  #36 (permalink)
Old 07-26-2005, 06:45 PM
pneall's Avatar
Millaz wheels. Contact is Pasquale Piccioli on 03 9725 2266. 144 Maroondah hwy.Is the new Snake tails advertiser.
Has any one had good/bad experience with OZ wheels since Tom sold the company??
Phil
  #37 (permalink)
Old 07-26-2005, 09:11 PM
Ralph_C's Avatar
Cobra Make, Engine: '85 Dax, 302W - "Street Boss", C4, Jag suspension
Thumbs up
Phil,
Purchased new wheels from OZ a couple of months ago - took a few weeks from order to completion (I picked them up, not delivered) but no issues (offsets, size etc. all as ordered).
Any one interested in a set of 16" ROH Monacos?
...Ralph
30 year old car - a work in progress
  #38 (permalink)
Old 07-27-2005, 02:06 PM
Thanks guys i will give millaz wheels a call and sus them out i will be ordering wheels this week so want to make sure i gat the best i can
Paul
  #39 (permalink)
Old 07-28-2005, 01:21 AM
HI All
Millaz wheels do halibrands for a bit over 3g but they dont as yet do pin drives which is what im after but they do seem to be a good wheel
Paul
  #40 (permalink)
Old 07-28-2005, 05:04 AM
Tony Cram's Avatar
Cobra Make, Engine: 1991 RMC 1966 427SC replica, 302 Cleveland, Edelbrock manifold with 600 Holley double pumper.
Thumbs up New Wheels
Paul,
A pic of my car with new Harry Witham Halibrand replica's.
