questions
- » Blogs
- » Image Gallery
million posts!
November 2025
| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
04-23-2005, 03:40 AM
Sidepipes.
Just posted some pictures of my sidepipes. Nick, who is the guy making them says he still has a few thing to do, but Im stoked with the way theyre turning out.
Regards.:
Mando
Advertising
04-23-2005, 04:07 PM
Cobra Make, Engine: 1st Harrison with Gen 3 , 6 speed ,Godzilla diff & brakes
Hi Mando
They look pretty good to me . Does your exhaust exit rear of car or are you going to try to get them through rego as working side pipes
Paul
04-23-2005, 08:48 PM
Hi ledge,
At the moment the exhaust exits at the sidepipes. If I had enough room I would like to run the pipes over the rear suspension, install some muflers and exit at the rear. I think I can only run under the suspension towards the centre of the car and Im not keen on that. It would be nice to pass Registration with sidepipes. I think Ill have to run a 1 3/4" undercar system to get down to 90db.
Regards.
Mando
04-24-2005, 01:19 AM
Hi Mando
Mine had to go out the back to get it below 90 . If you look at my pics it is hard to see were the pipe goes , The rear of the system is bolted on and after rego i will un bolt it and put just tips on .
Dum rules anyway.
Paul
04-24-2005, 06:53 PM
NT
Wow Ledge, it looks like you are makeing great progress with your car, it wont be long and you will be driving
Cruising in 5th
04-25-2005, 04:20 AM
Ledge, I can see the exhaust pipe running back under the car. Is the pipe 2"? Did you custom make the mufflers or were they of the shelf?
Regards.
Mando
04-25-2005, 03:21 PM
Hi Mando
It is 2" pipe it basically goes straight to the middle were they both join and then one runs out the back . As i have an independent rear the pipe didnt need to go over the diff .
The system was made bt Rotaflo in Mt Barker ( They are now called Carline ) . IT has 3 inch headers then a 4 inch flex then out the car to a 4 inch high flow cat and the muffler . i will attach some more pics tonight as it is out of the car .
Paul
04-26-2005, 02:49 AM
Added a couple of pics
Paul
04-26-2005, 10:01 PM
Pictures look good Ledge. Correct me if Im wrong, but are the sidepipes solid mounted, and any movement from the motor is taken up by the stainless steel ball/knuckle that connects the extractors to the start of the sidepipes.
Regards.
Mando
04-27-2005, 02:05 AM
Dont need to correct you
Im sending the headers away to hpc and the pipes will be polished . What about your pipes are you polishing them or coating the whole lot
Paul
04-27-2005, 04:28 AM
If I had to choose today Id probably get the pipes coated in flat black and keep the stainless steel section in the middle polished. Does the 2" pipe that runs to the rear of the car hang lower than anything else or is your chassis geared up for that setup?
Regards.
Mando
04-27-2005, 06:27 AM
Because the pipe was put through the wheel arch instead of under the floor pan where most people run it after it leaves the side pipe it tucks away nicely from memory the exhaust is not lower than the floor wich is a good thing , The rear muffler is visible from the drivers side of the car if you squat down a bit but the fuel tank is lower than it anyway . BUt after rego it wont be there anyway
I like your pipes cause you can see the 4 into 1 on the outside of the car , does yours need an oxygen sensor and if so where are you putting it . Thats the main reason i put mine into a collector before it exited the body as i didnt want the sensor hanging under the car in plain sight
Regards
Paul
04-27-2005, 10:47 PM
I need to run an oxygen sensor as well. If I remember correctly the guy making the pipes said it would go about centre of the 3" pipe that the 4 2" pipes go into and located at about 5 oclock looking from the front. If you look hard you should only see a couple of wires crossing the gap. Ive also left a decent gap between the pipes and the body. Ive noticed on a few cars the paintwork had bubbled and blistered from the heat generated by the cats in particular
Regards.
Mando
04-28-2005, 04:33 AM
Cobra Make, Engine: Classic Revival, LS1, Shift kitted auto, high stall, AU LSD rear.
Mando,
Your sidepipes are looking great.
You're going away from the rear exiting idea?Why?
Oh, and your shed is growing well by the photos, what have you been feeding it?
Talk soon Gav.
04-28-2005, 10:35 PM
Hi Gavin,
I wish that shed was mine. It belongs to the guy making the sidepipes. I also wish there was a 100% foolproof answer in setting up my exhaust to meet the required 90db with my motor. I dont mind running two pipes from the rear of the sidepipes up over the suspension in the wheelwells and out the back with a couple of custom muflers on each side but I dont think Ive got enough room for it. I also didnt mind Ledges setup with the two pipes collecting in the middle of the car and exiting out the back under the tank. In my situation it would end up to low.
A couple of guys have told me the only way Im going to get to 90db is to remove the sidepipes up to the extractors and install a 1 3/4" under body system. Installing the system doesnt bother me, its the extra holes to support the pipes that will anoy me. I had a look under the car last night, and I should be able to fix brackets to existing bolts such as the seat bolts.
Regards.
Mando
