Old 08-04-2005, 06:17 AM
simon clemens's Avatar
Cobra Make, Engine: Lucus shell, Arrow chassis, efi 5L HO, 5 spd supra, Diff 3.73:1, Rear tyres 275x60-15
Lightbulb Exhaust DIP COATINGS
Hi all, I like to know if there is a system where mild steel exhaust components can be dipped into a solution for better coverage of hard to get places... the reason I ask is that I have built twin-skined quad pipes and I'd like to have a product applied to all surfaces inside and out. The twin-skined pipes have a 3mm air gap between them, this is where spraying a coating will not be sufficient enough to prevent corrosion.
Chromate dipping is this for all types of metals or just aluminium? and is is good stuff for appearance/corrosion?
OR is ceramic coating able to be dipped instead of static spraying?
Is there such a thing as stainless steel plating?
If anyone has any information which could help me out... please do!!!
Simmo
Black Rubber Needs To Be Layed
