Old 05-02-2006, 05:48 PM
Tenrocca's Avatar
Default Brake and clutch pedal set up
Hi all. Ive been tinkering with the brake and clutch pedals and have a couple of questions:
I have 3 holes in the bracket for the pivot bolt. Has every one put theirs in the furthest forward hole? If I do this it appears the cylinder push roads would need to be shortened by more then the 15mm as suggested in the comprehensive build manual.
The brackets for the brake pedal are not centralised between the 2 master cylinder mounting positions. Going by memory I need to offset the pedal 8mm to the right of centre for it to be in the middle of the 2 cylinders. This seems a lot and going by everyone elses gallery pics mine is a little more out then normal?
Cheers.
