Old 05-25-2006, 07:58 PM
Cobra Make, Engine: Classic Revival 3506
Default CR steering column ???
Hi all me again about to go out and buy bits for my baby and want to know which steering column is the best to use on a CR ?
Thanks Paul
Old 05-29-2006, 07:52 PM
Leeroy's Avatar
Paul
Sorry but very slack on us CR owner/builders not to have replied yet.
Mines a '91 Suzuki Swift which for me worked out just fine. Hardest part is finding a nice cover & stalks which are not too faded or damaged.
I also have the wiring/colour pinouts if you need them as they are the same as the Holden Barina which is also recommended.
I found a good Suzuki wreckers in Braeside VIC that had plenty of Swifts to choose from which made it easier.
Leeroy
Old 05-29-2006, 08:13 PM
pneall's Avatar
Paul,
Have a talk to Churchy next Tuesday...he will fill you in on the adventures of buying a steering column....excuse hiom if he starts frothing at the mouth
Phil
Old 05-29-2006, 09:49 PM
Cobra Make, Engine: Classic Revival. LS1, T56, Billy Cart
Steering F%^&* column, I can tell you which one NOT to buy
You need to get the one with the 95 mm front mount centres. NOT the one with the 130 mm front mount centres.
All the dimensional information proudly sponsored and brought to you by Aussie Mikes remedial school for setting dummies (like me) on the right track..
Old 05-29-2006, 10:12 PM
Aussie Mike's Avatar
I've got the wrong version column sitting on a shelf in the back of my shed (Going Cheap). You (like me) obviously didn't read the section in the manual specifying which version of Suzuki Swift / Holden Barina column to buy.
Churchy is right, look for the version with the narrower spaced mounting holes behind the cowl. They also have rubber boots on the stalks which are hard to find in good condition. I brought mine back to life a bit by soaking them in silicone lube spray.
A coat of wrinkle finish paint on the shroud brings them up a treat. A lot of us have painted them this way with good results.
You can sort of see the switch gear and shroud in this pic to get an idea of what to look for.
Mike Murphy
Melbourne Australia
Old 05-29-2006, 11:46 PM
Thanks guys for the info, but i had purchased one on Saturday and not too sure if its the right one yet ??
I wish Ian was a little more informative with his Parts to buy list.
Old 05-30-2006, 12:12 AM
pneall's Avatar
Paul,
Bring your column to show and tell on Tuesday....all will be revealed.
Phil
Old 05-30-2006, 12:19 AM
I will even be able to show you the Steering wheel boss you will need if you are using a Sparco leather wheel...
Let's hope that is the right one
Old 05-30-2006, 06:54 PM
Mando's Avatar
Ptrefry,
I sprayed my shroud with wrinkle paint same as Mike only in black. It gives it that 60s look if thats what your after.
I didnt think there was anything wrong with Ians parts list incorporated into his comprehensive build manual! Yeah Right.
Regards Mando.
Mando
