Old 05-26-2006, 09:39 PM
Cobra Make, Engine: Classic Revival. LS1, T56, Billy Cart
Default Got Some New Bits
Hi Gang,
Well we have some new bits at home. Picked up the engine and gearbox. We will have to start work on them to have them ready to go in. Gearbox does not need a lot of work, however the engine is shy of a fews bits.
We need a wiring loom, throttle body and various other bits. The engine has been laying around for a while so we are going to take it apart and put new bearings, rings and valve springs in. The price we paid was way to good to pass up, so we didn't.
Old 05-26-2006, 11:31 PM
Cobra.au's Avatar
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
Hi Churchy
Let me know what bits you need as I have a fare bit of excess ls1 stuff.
Craig W
Central Coast NSW
Old 05-26-2006, 11:48 PM
Default Craig, your on mate
Thanks Craig, I sure will do, I need to find out what we are missing and then I will certainly be in touch. Thanks for offering.
Old 05-27-2006, 12:06 AM
Tenrocca's Avatar
As I sad Mark, the gearbox clearly is not the one you and Pete intended to put in the car, so I reckon you should sell to me, for lets say, a carton of Carlton draft??
Old 05-27-2006, 05:16 AM
Cobra.au's Avatar
I am also looking for a T56 6 speed so if any body knows of any please let me know.
Craig W
Central Coast NSW
Old 05-27-2006, 05:29 AM
Aussie Mike's Avatar
Congrats Guys on getting some important bits and confirming your dark side membership
Craig, what's up with your TR3550 5 speed box?
Mike Murphy
Melbourne Australia
Old 05-27-2006, 06:00 AM
Cobra.au's Avatar
Hi Mike
There is no problems with the 5spd when I rebuilt it I upgraded the input shaft, main shaft and other bits to bring it in line with the TKO box but with the higher overdrive for crusing (trying to keep the noise level down).
I am just not happy with the low first gear so I am now looking to buy new (or rebuild) a heavy duty t56.
I gess I am in the same boat as Gareth so how is his T56 holding up.
Craig W
Central Coast NSW
Old 05-27-2006, 03:59 PM
Thanks Mike, the Dark side is getting stronger. The federation is gaining strength.
Andrew, mate, make it a case of Crownies and you may have a deal..... Hang on.... Bugger that.... how about an LS2 ??
Old 05-27-2006, 04:30 PM
Craig,
I have a spare T56 but I do not want to sell it yet.
PM me if interested.
Ben
Old 05-27-2006, 04:44 PM
boxhead's Avatar
When you know what you need Churchy, put a list in here - I too have some spares.
Cruising in 5th
Old 05-28-2006, 04:23 PM
Default The heads are off
Well, we took the heads of yesterday and everything seems to be in really good nic. However we are going to do rings, bearings, and timing chain. The valve springs look OK, so we are not going to do them.
So the parts list so far is throttle body and a starter motor.
Old 05-28-2006, 07:30 PM
pneall's Avatar
Churchy,
The one must do thing on a Gen111 is the valve springs. I just happen to have a set of Comp 918's available ...only done 500km's. Catch up at the Cobraholic meeting.
Try ebay for the starter and TB.
Phil
Old 05-28-2006, 08:26 PM
Cobra.au's Avatar
Phil
Are you doing some head work on the gen3 to have a set of 918's spare
Craig W
Central Coast NSW
Old 05-28-2006, 11:45 PM
pneall's Avatar
Craig,
Sure Am.by Nathan Higgins.
Phil
Old 05-29-2006, 03:18 PM
Tenrocca's Avatar
Craig, for a brand spanker this aint too bad?
http://cgi.ebay.com.au/Tremec-6-spee...QQcmdZViewItem
Old 05-29-2006, 03:20 PM
Tenrocca's Avatar
And this is the first LS2 Ive seen on Ebay (Australia)..
http://cgi.ebay.com.au/NEW-LS2-6-0-L...QQcmdZViewItem
Old 05-31-2006, 05:40 AM
justbetter's Avatar
Cobra Make, Engine: Superformance AUS002, Chev 5.7 with hairdryer
Default T56
Craig, mikes handy work in the Viper upgrade in the T56 is good, still hanging in, firm, no shudder, can slam it, up and back thanks to a great verrry expensive clutch.
Waiting to see if it handles a new LS7...
Car in the shop at the moment for a big brake upgrade.
Got to go home after working later these days to pay for all this stuff.
looking forward to seeing you at the nats
Garrett
Garrett
COBTHS
Superformance SPF AUS002 "Modified"
Old 05-31-2006, 05:53 AM
Hi Craig,
Garretts box got new syncronizer assemblies for 3-4 and 5-6, Billet steel synchronizer keys, new synchro rings and a steel 3-4 shift fork from the viper box.
The gears them selves were in good condition still just the dogs were taking a beating. The pressed steel keys flex, bend or break and cause the synchronizers to hang up when shifting hard causing more wear on the dogs. I think the dogs are going to be the weakest link in these boxes and that all comes down to how hard you plan to shift. Garrett takes no prisoners with the shifter and it seems to be holding up OK (time will tell).
The next step up would be to use a G-Force cluster which has only a slight angle on the helical cut gears (they are almost straight cut). They also have triple cone synchros for 1-2 and 3-4 where the standard box on has them for 1-2 . The dogs on the gears are also removable so you dont have to replace the whole gear.
It's not a cheap option though as the G-force cluster is nearly US$2K before you even get it landed in Aus.
I'd try a beefed up standard T56 first and see how you go.
Mike Murphy
Melbourne Australia
Old 07-15-2006, 07:21 PM
Starting to get exciting for you now mark. We have started the wiring at this stage.
Mike Freeman
Old 07-15-2006, 11:37 PM
Are you using the painless wiring kit Mike?
Ben
