Old 06-10-2006, 07:11 PM
Cobra Make, Engine: Classic Revival. LS1, T56, Billy Cart
Default Jag Front Sway Bar Mounting
Hi,
A lot of the CR guys now have a shiny red sway bar for the front of the Classic Revival. I got to thinking "how am I going to mount that to the Jag mounting points"
I knocked up this bracket and I think it will work.
I used the Ford bracket from the rears (cause that's what I had) and threaded an M12 mounting point to mount to the Jag bracket.
This Photo shows how it mounts.
It's only a prototype and I made it from Mild steel. I think it will be OK, but I'm a sparky and not all that clued up on mechanical design and load. If you guys that got the shiny red sway bars, have some suggestions, on what it should be made of, or is steel OK ?
I think the guy at Pedders may have some better connecting brackets (not the Ford one's). I will have a chat with them and see if I can come up with something that's not quite as big.
If it all works out, I am happy to make them for the gang who recently got sway bars.
Old 06-11-2006, 04:47 PM
Cobra Make, Engine: Classic Revival 3506
Default In the sway of things
Churchy look good count me in (if it works)
Thanks Paul
Old 06-12-2006, 02:09 AM
boxhead's Avatar
Sure looks good to me, I cant think of any reason why it wouldnt be strong enough.
Cruising in 5th
Old 06-12-2006, 04:28 PM
Hi Boxhead,
My mechanical engineer (uncle Phil), has given it the thumbs up and also reckons that it can be made from Aluminium. I will get the Ford part numbers for all the Ford bits and let people know.
If you guys with the shiny red front sway bars on CR's want them let me know and I will go into a small scale production run.
Old 06-12-2006, 05:20 PM
Count me in!
Ben
Old 06-13-2006, 02:48 AM
boxhead's Avatar
I still have my cough cough Ford cough cough (damn swear words) parts so all I am going to need is the little bolt thingy you have made.
Cruising in 5th
Old 06-13-2006, 04:43 AM
cobbindale's Avatar
Same here if you don't mind Churchy.
Dale.
Old 06-13-2006, 04:13 PM
PCC's Avatar
PCC PCC is offline
Churchy,
Yes I need a couple of those aluminium thingymjigs assuming I can still get a sway bar.
Good to know that it will fit on the Jag front end. Hopefully the fact that my car is a DRB won't be a problem.
Have you got a contact number for the sway bar itself? Hopefully Pedder's have some left!
PCC (Peter Craig)
Keep the sun shining
Old 06-13-2006, 04:50 PM
Hi Gang,
OK, a small production run has been planned and I should have them finished around the end of the month. I am heading over to Perth next week to watch the Wallabies smash the Irish tourists (Go you good things !!). And with the new Work Place Agreements. I am not allolwed to take the mill/lath on the plane.
When I have them finished I will grab all your address's. I will also find out this weekend, if all the Ford parts are available and get you part numbers. No point in shipping stuff that could be right next door to you.
Old 06-15-2006, 04:47 AM
RODA's Avatar
Cobra Make, Engine: Classic Revival LS1 6spd
Churchy
You can count me in on a couple of those shinny aluminium thingies as well.
What are those black thingies above the aluminum thingies, cause I need 2 of those as well.
If you can let me know what they are that would a great help.
Phil any chance of a photo of how you have mounted your sway. Have you used black and aluminium thingies as well
Rod
Old 06-15-2006, 04:40 PM
Roda,
The black thingies are the Ford rear sway bar attachment units. They mount between the rear lower control arm and the rear sway bar. And seeing as Ford had done such a great job of these (and I had 2 laying around), i used Mr Ford's brilliant idea.
The shiny aluminium thingies have not started production as yet. I will probably start on these in around 2 weeks time. I've got a Wallabies game to attend. Yipee...
Cheers Churchy
Old 06-16-2006, 01:33 AM
cobbindale's Avatar
Default Sway Bar Links
There are a number of link setups available from Pedders.
The one that looks close to Marks picture is the 4204 which has 10mm threads and 60mm between centers. They are around $52 each and are from front sway bars for Camry, Corolla, and Apollo's.
The larger 4208 is listed as the AU Ford rear sway bar link (and about 60 other cars) and can be cut to size. The threaded rod is fixed to one joint and screws into the other as shown in the picture at around $55 each. Instead of using both joints on one side, it may be possible to use traditional bushings (jag setup) at the jag control arm mount and the new ball joint at the sway bar requiring only one unit instead of two. A nice polished peice of stainless tube to cover the thread perhaps. Just a though and depends on mount positions.
Dale
Old 06-16-2006, 02:02 AM
RODA's Avatar
Churchy
Thanks for the info I think I will also use Mr Ford's idea.
Dale
I am going to go to pedders and get 2 of black thingies that Mr Ford used. Do you think my descripstion will be good enough.
Rod
Old 06-16-2006, 07:15 PM
Guys,
I would suggest the Pedders unit as Mr Ford wants $68 for his units. The mounting nut for the shiny aluminium thingie is an M12 nyloc nut.
So, Pedders for the black thingies. Churchy for the shiny aluminium thingies and your favourite M12 nyloc nut supplier.
Old 06-17-2006, 12:57 AM
Cobra Make, Engine: Classic Revival (under construction)
Hi Churchy
Could you count me in for a set of your patentented "shiny things". Let me know price etc when you are ready
Many thanks
Philip Chisholm
Old 07-02-2006, 02:12 AM
Default Production Line
Hi Guys,
Well the production line has started for the shiny thingies.
So if you can PM or email me your address (interstate guys) I can start postng as they come off the line.
NSW guys, I will see you all soon for a group therapy session, and I can give you the shiny thingies then.
Old 07-02-2006, 03:26 AM
Hi Churchy
I have PM'd you
Philip Chisholm
Old 07-13-2006, 11:14 PM
Default You have mail (the snail type)
Boxhead, Cobbindale and Philchis,
You should have some shiny aluminium thingies in your mailbox.
Roda, Beejay, ptrefry, philm and PCC yours should be rolling off the production line this weekend. Roda and PCC, can you PM me your address so I can post.
Old 07-14-2006, 01:42 AM
cobbindale's Avatar
Hi Mark,
Received package today with nice little aluminium thingies inside.
Thanks heaps.
Dale.
Old 07-14-2006, 09:48 PM
boxhead's Avatar
I have a note in my Po Box - now I gotta wait all weekend to see em.
Cruising in 5th
