06-13-2006, 07:43 PM
NSW
Cobra Make, Engine: Classic Revival 3506
Chrome hand brake lever
Does anyone know what model MG handbrake lever you use in CR kit.
Also has anyone fitted it to the left hand side of the car ?
Thanks Paul
06-13-2006, 08:50 PM
NSW
Gday Paul, Mine was from a 72 MGB, but Im not sure if they changed from model to model. I reckon you could put it on the left, just have to move the bracket? I turned up a new grip and button yesterday (inspired by a welll known contributer to the forum - if you cant come up with a good idea steal someone elses  ). The rest of the handle looks like a dogs breakfast, but It'll be covered by a boot eventually.
06-13-2006, 09:14 PM
NSW
Cobra Make, Engine: Classic Revival. LS1, T56, Billy Cart
Andrew,
Do you have the detailed plan diagrams for that nice shiny bit ?? Or did it just happen. Did you make two ?
They sure are purdy.
06-13-2006, 11:38 PM
VIC
Thieving Scoundrell!!!
Lever is from an MGB. The MGA is very similar except it has a push to lock button rather than a push to release.
I got mine from an MG specalist in Richmond that I cant remeber the name of. Cost me about $150 from memory.
I went for the painted one and sand blasted it and gave it a lick of paint. They have a fairly nasty plastic grip and button so replaced them with a machined up aluminium one that adds some bling and feels nicer when pressing the button.
Mike Murphy
Melbourne Australia
06-13-2006, 11:48 PM
NSW
Mine looks a bit shorter and fatter then yours Mike, but according to "Cosmopolitan" its width that is important
06-13-2006, 11:53 PM
VIC
I've got wider deeper ridges and more of them plus my knob on the end is bigger. My wife had a pull on it and said the action felt great. Shows what you know
Mike Murphy
Melbourne Australia
06-14-2006, 12:23 AM
NSW
 hehe
06-14-2006, 12:50 AM
Qld
Handrake
Mine has lost its tension, the adjusting nuts need a tweak.
06-14-2006, 02:07 AM
NT
Um ,,,,,,,, Mine is worn out
Cruising in 5th
06-14-2006, 04:52 AM
VIC
Too much play in the mechanism. Probably needs re bushing.
Mike Murphy
Melbourne Australia
06-15-2006, 05:38 PM
Vic
Paul,
Picked up hand brake lever yesterday from MG parts supplier, i just asked for the chrome lever from MGB with 3 CSK screw mounting he knew straight away it was for a Kit car, with that description the part was what was required and fitted to chassis no probs, mind you the chrome is a bit ordinary but will clean up. The MG guy said they came in black painted or chrome, I paid $100 for mine.
regards,
Nigel
06-15-2006, 11:19 PM
Zzz
Mmmmmm copying the sincerest form of flattery.
Looks great.
Bernie Knight
06-16-2006, 12:08 AM
WI
Bernie,
would that be a copy of a copy of a real one
Cameron
06-16-2006, 12:32 AM
ACT
Paul
I mounted mine on the left of the tunnel. In the early G-Force the tunnel is slightly scalloped on the passenger side and it sits in just nice. Gives me more room in the drivers seat.
I used a Mazda lever with woodgrain handle. Leather boot covers most of the lever leaving just the handle exposed.
SLIPRY
06-16-2006, 02:34 AM
Zzz
I have seen a Jaguar handbrake used - an early floor mounted lever that was approximately 380mm - 14" long with a pronounced push button top.
Bernie
Bernie Knight
06-16-2006, 02:39 AM
Zzz
Cameron
Now is this a trick question? - were you put up to this by either SPF or CS himself.
Mmmmm - short answer..
It's a rough 'copy' taken from an 'original copy' that was previously 'traced' from a 'copy' of a xerox 'photocopy' of a black and white 'photo' that was stuck to the WC wall after being allegedly torn from a genuine 'copy' of a book that was stolen from the a reproduction car manufacturer in the UK..
Now I'm confused. Guess, I don't know where it come from..
Bernie Knight
06-16-2006, 03:36 AM
Vic
Cobra Make, Engine: Superformance AUS002, Chev 5.7 with hairdryer
Position
Bernie looks like both you and your wife can grab it from that position, looks like you can occasionally keep both hands on the wheel.
But i heard you wife dont travel with you much, good thing you got a grip on life.
For the record Aussie Mike modified mine and it works just like his...., but had to have it tweeked, needed more leverage as started to loose feeling at , $hit, OUCH, But But But Babe i wasa just saying fun, OUC, WHACK< OUCH WACK, things to the Guys, OK OK.
For the record when we go parking, WACK Ouch WACK, Sorry when i park the cobra the hand brake works fine ...
Garrett
COBTHS
Superformance SPF AUS002 "Modified"
06-16-2006, 09:26 AM
VIC
Polished Knob
Hmmm...
Since everyone is showing off their knob I thought I'd join in:
Of course, me being the anti-Mike, the handbrake is a spare found in the body on arrival, a piece of angle iron welded to the top of the drive-shaft hoop - a couple of nuts and bolts - and there you go.
Angle Iron and cable ties - everything you need to build a Cobra
LoBelly
06-16-2006, 11:25 PM
i used a mazda 323, ford lazer i think. then i got snak bite to make a handle for it, got a bit hot in summer thou. o then he made some more and more.
still got to get back to the side pipe questions.
06-17-2006, 03:56 AM
Zzz
Just saw that LOKAR offer a variety of original looking handbrakes well under $200 Aus.
Australian Street Rod magazine #193 page 78 - LOKAR distributor is HOT ROD HARDWARE in Victoria on 03 9752 6555
Same magazine #193 page 54 - LOKAR distributor in Queensland is SUPERFORMANCE on 07 32064400 and www.superformance.com.au
Good hunting......
Bernie Knight
