Old 07-04-2006, 11:35 PM
Cobra Make, Engine: DRB 1999, 302w
Default questions about ignition leads
Hey all, just wanted to get a bit of info about ignition leads. I am replacing mine but am wondering what is the advantage or disadvantage of using 8.8mm or 10mm leads (currently have 8mm). Is there a better spark? The diameter of the wire inside seems to be the same, just more insulation. Also is there a brand that is best? I was going to use Top Gun, but is there something else you recommend? Thanks for everyone's help.
cheers
Dave
Life is not about how many breaths we take, but about how many moments take our breath away....
Old 07-05-2006, 10:52 AM
Bryan Wilson's Avatar
Default Ignition leads
Dave,
I use Top Gun 8.8's because of the thicker insulation and you can get them in a kit so you can cut them to length yourself and do a neater looming job.
With the premade ones you often end up with some either to long or to short.
I made my own crimp tool for crimping the clips on the wires.
Bryan
VK3KDN
Old 07-05-2006, 07:21 PM
I reckon the best leads come from here, http://www.iceignition.com.au
They will custom make the leads to the lengths you specify....
