07-16-2006, 07:26 PM
Progress
Dash is in, wiring is on the way and plumbing is 1/2 way there. Progress. When will it end?
Regards.
Mando
07-16-2006, 07:44 PM
qld
looking good mando, one sweet motor you got there . and when does it end ?
it dont!
07-16-2006, 07:50 PM
Mando,
it would have to be one of the best I have seen and its not finished yet, as I said can't wait for you to finish it, good luck
I see that you have stayed with the commodore cooling fan, any reason did you do any comparisons, I just thought that it took up too much room.
Steve
07-16-2006, 11:16 PM
WA
That looks fantastic Mando! Can't wait to see the finished product...
07-17-2006, 02:22 AM
Cobra Make, Engine: Classic Revival, LS1, Shift kitted auto, high stall, AU LSD rear.
Looking great mate.
Your workmanship is a credit to you.
Gav
07-17-2006, 06:35 PM
NSW
That engine is a work of Art. unbelieveable. Real credit to you Mando. How did you get the rounded seamless finish on the footbox panels?
07-17-2006, 07:00 PM
Man, that is like a piece of jewelry. It may seem like it is taking a long time but it is paying off in the results you have.
6th generation Texan....
07-17-2006, 07:48 PM
Kanga, I bought the fan shroud early in the build and went with it because it has an old look to it. It probably does look a little out of place in a high tech engine bay but I dont have much else to put in that area and Im happy with the look. I also had a header tank the same as you find on 427s, but had to loose it for the smaller fitting where the 4 water points enter and exit through the radiator hose with a cap on top. I couldnt make it work neatly with all the hoses and the original header tank.
Tenrocca, I bent the stainless sheets on a large press that had interchangeable sections to alter the finish to the corner being folded. The stainless cover sheets were laser cut. If anyone wants a copy of the program they could get them cut locally. Ive allowed for 6mm aluminium washers to go between the stainless and the fibreglass for an air gap.
Regards.
Mando
07-30-2006, 11:52 PM
NSW
Mando,
I have been looking at those stainless engine bay panels of yours again and I think I dribbled on my laptop!
Is there much welding involved? I have a feeling the only people down here who could do this are commercial kitchen makers????
Ben
07-31-2006, 03:41 AM
That is blu$$y nice.
07-31-2006, 04:55 AM
Zzz
Whoaa Mando looking great
Bernie
Bernie Knight
