Old 09-18-2006, 09:42 PM
Cobra.au's Avatar
Cobra Make, Engine: Classic Revival, Gen3 ls1, Vortech T-Trim, Motec, tremec M12, wilwood brakes.
My fabricator told me that its not a problem to do I will get the pipe pre bent then he will work out the profile to cut with the plasma and then it should all fit together sounds easy when he said it, also I will need to buy him a straight tig torch to weld it all together internally.
I will take plenty of pictures as we go so you can see the process involved
Craig W
Central Coast NSW
Old 09-19-2006, 06:32 AM
Jerry Clayton's Avatar
To make a simple jig to cut the tubes--use a square piece just oversize of the header tube size--weld on a piece to clamp the curved piece--cut lengthwise thru the curve with a saw, turn over 90* and cut second side--they all should fit together perfectly--practice on mild steel, stainless is $$$$$
Cut back the joined end to the diameter you want, you will probably want to pretrim so the tig torch will fit in the opening
I've started just buying mine from down in Nascar land!!!
Jerry
Old 09-21-2006, 05:06 AM
Gav's Avatar
Gav Gav is offline
Wind the wick up on the vortec and the gases WILL get out somewhere high flow cats or not!!
Old 04-11-2007, 09:41 PM
Cobra.au's Avatar
Well the Cobras been on the back burner for a while but I am now back into it with a vengeance here are a few pics off the collectors that we have fabricated they are 2" primaries into 3 1/2" that will step up to a 4 1/2 pipe
Craig W
Central Coast NSW
Old 04-11-2007, 10:28 PM
CHANMADD's Avatar
Nice job! Those should flow very nicely.
Old 04-11-2007, 10:42 PM
Mando's Avatar
$hit, they look fantastic
REGARDS.
Mando
Old 04-12-2007, 04:36 PM
Cobra Make, Engine: RCM, 4 wheels, two doors
Nice pipes!
A BOSS in a GT40 - cool!
Old 04-12-2007, 06:11 PM
Aussie Mike's Avatar
Welcome to the Forum Dimi. Nice setup you've got there. How did you go getting it through the noise tests?
Mike Murphy
Melbourne Australia
Old 04-12-2007, 07:21 PM
Dwight's Avatar
Smile
Thanks, side pipes will be my next big upgrade project.
Dwight
Old 04-12-2007, 07:49 PM
RedCSX1's Avatar
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Default Beautiful work
Just awesome fabrication
Morgan LeBlanc
Fresno CA
Old 04-13-2007, 05:58 AM
Dimi,
Clearly I went to the wrong people.
Nice work, mind if I ask how much? PM me if required.
Beejay
Old 04-14-2007, 07:50 PM
Cobra Make, Engine: Scratch build
Nice small Cats, what are they from?
Old 04-15-2007, 07:38 AM
Default RE; Small cats
Hi
Not sure what the cats were but they are stainless and were shortened to fit into the available space.
Oxy sensors were also fitted into the cats both before and after as per the stock Boss engine setup.
Dimi
Old 04-15-2007, 01:38 PM
Cobra.au's Avatar
They look like metalcats to me.
Craig W
Central Coast NSW
Rate This Thread:
